More recalls
Old Sep 7, 2005 | 04:12 PM
eric james's Avatar
eric james
Ford's story line: http://media.ford.com/article_displa...&make_id=trust
Old Sep 8, 2005 | 01:37 AM
hallam's Avatar
hallam
Recall Concerns - Eh!
Originally Posted by fordman15
The affected vehicles include: 1994-2002 model F-150s, 1997-2002 Expeditions, 1998-2002 Navigators and 1994-1996 Broncos equipped with factory-installed speed control.
I bought my truck last December and registered directly with Ford as the new owner. When I heard about the recall today I went to Ford's site to confirm if my truck was affected-- and got the following response:
Recalls
VIN: 1FMFU18L9VLA61240
Number of Items: 1
Item ID: 05S28
RecallDate:
Title: SPEED CONTROL DEACTIVATION SWITCH
Description
Disclaimer:
This system tracks National safety and emission recall notifications on vehicles registered in the United States at the time the recall was initiated for programs that were launched on or after January 1, 1996. For more information on Ford Motor Company recalls/vehicle campaigns, Regional recall programs, or concerns you may be having with your vehicle, please contact your dealership directly.
Problem - I contacted a local Ford dealer here in Ottawa Ontario, and they ran my VIN and categorically denied any outstanding recalls. I quoted them the response from the Ford site. They responded that they were directly connected to Ford's system, they saw no recall and wished me a good day.
Do I wait for a recall notice from Ford? I have a feeling I won't see one.
Is there a difference between trucks built in the USA for Canada with respect to this recall. I'm a little confused...
My truck is a '97 Expedition XLT 4x4 5.4L
Old Sep 8, 2005 | 07:16 AM
01silvergt's Avatar
01silvergt
Recalls
Number of Items: 1
Item ID: 05S28
RecallDate:
Description
Disclaimer:
Call another dealer, or wait for the letter. If another dealer is not possible, then print the page from the site and print the recall notice from the Ford site and take it to the dealer.
Old Sep 8, 2005 | 08:57 AM
ms6073's Avatar
ms6073
Originally Posted by 01silvergt
Did you buy the "fixed" switch from Ford? If so you can get your money back.
Yes but based on the part pictured in this image:
This time it appears Ford has issued a new wiring harness to be plugged inline between the swtich and existing wiring harness, not a new swtich which was addressed by the previous recall.
Old Sep 8, 2005 | 10:40 AM
01silvergt's Avatar
01silvergt
After reading more into this, it does not look like ford is replacing the switch like the other recall. So if you replaced the switch, then you will most likely not get you money back. If you bought the new harness, then you could. Think of it this way, you got a new switch and have / are getting a fused harness, I would feel better with this setup more so than those of us that only get the fuse.
Old Sep 8, 2005 | 10:43 AM
Icefan71's Avatar
Icefan71
http://www.ford.com/en/innovation/sa...iseControl.htm
video from Ford on recall
Old Sep 10, 2005 | 09:16 PM
JP6's Avatar
JP6
Stopgap solution to speed control issue
After reading the posts here, and noting that Ford is saying it may be months before there are enough fused wiring harnesses to supply the millions of trucks covered by this recall, I've disconnected the connector at the potentially defective master cylinder speed control cutoff switch.
So my truck and house aren't going to burn up. . . But my speed control doesn't work any more (duh!) And that got me to wondering:
If the switch (normally closed) on the master cylinder is a secondary sensor -- the primary being the brake light circuit -- to switch off the speed control when the brakes are applied, why not just jumper the leads to the controller after disconnecting the switch? Of course this would only be temporary, until Ford comes through with the new fused harness, but it lets you eliminate the fire hazard while retaining use of the speed control, albeit with one less safety cutoff in place. And folks who rely on "cruise control" for fuel economy and to avoid speeding tickets won't be left without a driving aid upon which they've become dependent
What do you all think?
Old Sep 11, 2005 | 07:35 PM
racerock's Avatar
racerock
I had the same thought a few months ago when I disabled mine based on the fact that they were still investigating. I'll have to check my schematic and get back - I have the factory manuals.
Old Sep 11, 2005 | 07:39 PM
racerock's Avatar
racerock
I think this fused jumper is a crock of S. H. I. T., is a bandaid to the real problem, and is Fords way of saving a ton of money! Personally, I want both the switch and the harness. Why do I want the switch?
Because it is the source of the problem. It leakes brake fluid, which is the starting point of the whole problem, right??? Fix the switch, fix the problem.
Then put the harness in as extra protection.
"Why does the harness save Ford money?" you ask. Well, watch the video. Mechanics can get the harness installed in less than a minute. To change the switch, they should bleed the brakes to do it right.
mtgrzlyman
Oct 26, 2012 08:53 AM
DBZ123
Jan 6, 2007 01:22 PM
Aftrmidnite
1997 - 2003 F150
Sep 7, 2005 09:27 PM
n0esc
Nov 4, 2003 06:06 PM
kcarcich
Oct 25, 2003 10:14 AM
