'89 Ranger "Project"
There are probably differences among code readers (I got mine at Shucks), but the way my son described the process, the three-digit numbers appeared in the digital readout the first time around, along with a blinking light, with the first number repeating itself at the end of the whole sequence of eleven codes. Then for some reason, the eleven codes repeated themselves after a slight pause, but this time only with the blinking light (no digital number readout this time). My son said that it was hard at first to figure out what the code reader was doing, but then he realized that the blinks corresponded to the initial sequence of eleven numbers, with short pauses between each number and slightly longer pauses between each three-digit set of numbers. At the end of this second variation of the sequence, the light just started blinking continuously, with no further action.
According to the manual, what is supposed to appear next is the number "10," which is the "separation code," This separates the Self Test Fault Codes from the second set of codes, which are the Continuous Memory Codes. I don't know why the readout never shows the number "10," and why it never moves into the Continuous Memory Codes. I also don't know why the Self Test Fault Codes are repeating themselves a second time, but without digital readout. One obvious possibility is that the car computer is malfunctioning, but when we bought the truck (which was not running at the time and had to be towed), the previous owner gave us a new computer that was still in the box, which he had been planning to install. So it would be kind of freakish if the computer turned out to be bad.
I can give you the descriptions for the eleven Self Test Fault Codes if that would be useful to you. As I said earlier, they are mainly solenoid circuit fault codes. But as someone said earlier (Dave, Irishguy?), they may not mean much anyway because they may clear automatically as soon as the lowest code in the sequence (the 123 "Throttle Position Sensor Above Maximum Voltage") is corrected. I will try to work on that tomorrow when I can get my hands on the truck.
Athough these were definitely three-digit codes, the code reader manual backs all of you up -- it indicates that most Ford EEC-IV vehicle computers up to 1991 use two digit codes, while those after 1991 use three-digit codes. Is it possible that the wrong computer is installed in the truck? When my mechanic picked up the computer (still in the box, I think) from the previous owner, he may have just installed it under the assumption that it was the proper computer for the vehicle. Maybe it wasn't.
It's curious that the code reader has never acted exactly the way it is supposed to, as described in the manual. It ran through the Self Test Fault codes once, repeated the first one in the sequence again, and then after a pause went through the entire eleven again with just the blinking light (no digital readout). My son said that it was hard at first to figure out what it was doing, but then he realized that there was a short pause between each number (three blinks for three, etc.), then a longer pause between each three-digit sequence. Then when it finished the second time, it just started blinking continuously. What it is SUPPOSED to do, according the manual, is to display the number "10" (the "separation code") after it displays the Self Test Fault Codes, and then start displaying the Continuous Memory codes. It has never given us the "10," and refuses to move into the Continuous Memory codes.
Any thoughts?
My largest problems turned out to be a plugged cat and the hose that connects the intank pump to the outlet tube was melted. Probably from an additive. Still working on a code 41 and running a test pipe for the cat until my new one arrives.
I will certainly check the numbers on the computer when I go down to my mechanic's shop in a few hours, but how would I check the year of the rebuilt engine -- and does it matter? I'm quite sure that it's a 2.9L, but what if it's a '90 instead of an '89, or a '91, etc., etc. How do you tell? (My mechanic would probably know this, but I'm asking just to make sure.
You might have to call Ford and ask them what the computer number should be for your year truck. With those 3 digit codes that's where I would start. I almost bought one that the last 3 digits were different until I got an answer to my post about it.
Understand that my mechanic has just been poking around the truck during his lunch hours and in between jobs. That was the agreement. So he hasn't been logging in long hours -- although over a six month period they have probably accumulated. I think he has begun to realize, though, that this vehicle had been seriously messed with before I bought it, and by someone who had no idea what they were doing. (For example, a number of wires in various parts of the harness have been stripped and re-taped.) So it's a little different than someone bringing a vehicle in to him that doesn't run quite right and asking him to get it up to speed again. He's good at that, but this has been much more of challenge.
Here's something else a little weird that my mechanic mentioned to me on Saturday. He had another, younger mechanic (factory trained and all that) helping him out with some major automotive projects a few months ago, and just for the heck of it he turned the Ranger over to the young guy one afternoon. The young mechanic's first reaction when he test drove the truck was that that it acted like it had a faulty EGR value, but when he looked under the hood hd couldn't find one. It appears that the intake manifold (which was probably bolted onto the original engine) has a flange and port coming out of the front right side of the manifold (looking front to back), but it is capped with a plate. The two mechanics figured that this is where the EGR value should have been. Does that signify anything, or were EGR valves optional with this engine?
