General Automotive Discussion
Taurus shifting annoyance
Old Sep 6, 2005 | 04:04 PM
johnfl's Avatar
johnfl
I have a 97 Taurus GL 3.0 auto. The tranny lost a carrier bearing a couple years ago and I had to get it rebuilt. Anyway, it seemed OK but now, since I travel back and forth between Phoenix and San Diego at least twice a month, I've noticed a couple things that drive me nuts.
1. It don't like to downshift 1 gear, it likes to jump down 2 and scream with absolutely no increase in speed. 1 gear would work just great but not 2.
2. and most annoying, the torque converter will drop out of lockup every 10 to 12 seconds consistently on the 350 mile trip. The RPM increases about 200-300 for about 1-2 seconds then locks up again for roughly 10 seconds then repeat. It doesn't matter if I'm going up a slight incline or down (like a freeway overpass), 65mph or 85mph, a/c on or off it rhythmically drops in and out of lockup.
Any link suggestions?
What kit would best serve my needs? I see a couple different ones advertised for this year Tortoise and way different pricing.
TIA
JohnF
Old Sep 6, 2005 | 04:05 PM
MisterCMK's Avatar
MisterCMK
Sounds like there is an adjustment that needs to be made. Take it to a reputable tranny shop, and see what they can do about it.
Old Sep 6, 2005 | 07:20 PM
Ford_Six's Avatar
Ford_Six
It sounds like there may be a throttle position sensor issue.
Old Sep 6, 2005 | 09:47 PM
Racerguy's Avatar
Racerguy
A bad TRS (Transmission Range Sensor) can cause the problem too.
Testing it is easy with a scan tool that allows you to watch live data.
Old Sep 7, 2005 | 12:01 PM
MisterCMK's Avatar
MisterCMK
The throttle position sensor doesn't really affect shifting at all.
Old Sep 7, 2005 | 12:05 PM
Casey's Avatar
Casey
Sure it does. The trans computer uses throttle position and vehicle speed to decide what gear to be in.
Old Sep 7, 2005 | 09:12 PM
Ford_Six's Avatar
Ford_Six
The computer looks at throttle position, MAP pressure, gear selector range, road speed, and a/c usage to determine the gear.
Old Sep 9, 2005 | 11:51 AM
Greywolf's Avatar
Greywolf
IT also sounds like low fluid...
There could be a bad vac line too, believe it or not.
Old Sep 10, 2005 | 09:44 PM
JerNla's Avatar
JerNla
I have a 2002 Taurus and I also hate the fact that it refuses to shift down one gear, and all it does is feel like the whole car is about to fall apart from the massive viberation, and yet it has almost no effect on the actual acceleration. An on the same note my car also does the fluctuating RPMs on Interstate, I was told that it was most likely a vacume leak but somehow I have never found out how to fix it. So if anyone can help it would not only help one person!!!!
Old Sep 11, 2005 | 02:10 AM
fordeverpower's Avatar
fordeverpower
i don't think 2 cents of the ax4n or the ax4s. I have broke the shaft in the ax4n and blew out the differential in a different ax4n. JUNK!!!!!!!!!!!!!!!!!!!!!!!!!!!
