OBDII Code reader plugs in NO JUICE
Old Sep 6, 2005 | 12:56 PM
dpbrowne's Avatar
dpbrowne
I have a 1996 F250 302 4X4. I bought a OBDII code reader and it doesn not even start up. I checked it with another truck and it works fine. How do I fix the truck wiring? My plug seems to be dead on the truck.
Old Sep 6, 2005 | 01:54 PM
Franklin2's Avatar
Franklin2
I don't have a good diagram of your truck's year and the datalink connector. The 96 diagram I have shows 3 wires coming directly off the engine computer. But the better 99 diagram I have shows there are 7 wires coming to the datalink connector. The same three come from the engine computer, but there are also two grounds, a black and a black/white wires, and there is a fused power source which is lightblue/white.
If these wires look the same on your connector, I would check for 12 volts from the black wire to the lightblue/white wire. There is a fuse for the lightblue/white wire in the fuse box.
Old Sep 7, 2005 | 11:41 AM
dpbrowne's Avatar
dpbrowne
Thank you I will check - Dennis
BAD RONALD
Mar 7, 2012 08:16 AM
DGMFORD
1997 - 2003 F150
Mar 16, 2007 10:12 PM
Madmike33
1983 - 2012 Ranger & B-Series
Feb 20, 2007 11:56 PM
johhan
Nov 2, 2004 06:38 AM
hreed
Dec 4, 2003 03:45 PM
