wobbly Front axle assembly
Old Sep 5, 2005 | 07:21 PM
Gary E's Avatar
Gary E
So I can wiggle the front u-joint and axles up and down a good 1/2 an inch. I assume this is bad, and will a new front hub assembly fix this?
Old Sep 5, 2005 | 08:08 PM
Kwikkordead's Avatar
Kwikkordead
Yikes!!! That's a lot of slop!
Shouldn't be too hard to find. Just start moving things around and find the source of the movement. Replace the offending parts and you should be good to go.
Old Sep 5, 2005 | 09:14 PM
westpsd's Avatar
westpsd
The same thing happened to mine last year. You will find the axle bearing have gone away and trashed the axles. New axles are very expensive, so I had mine built back up and turned at a local machine shop. You will need bearings, seals and u-joints to repair as well as either new axles or rebuilt ones. Last week, there was a post with a link on replacing ball joints. Most of the steps are the same to replace the axle bearings and seals.
John - Wenatchee
May 6, 2025 08:40 AM
Craftsman027
Oct 10, 2010 07:06 AM
zavierbr
Dec 23, 2008 08:39 PM
cma
Apr 30, 2001 07:24 PM
