pretty sure its the starter
Old Sep 4, 2005 | 08:47 PM
wagiles's Avatar
wagiles
Exclamation pretty sure its the starter
starter wouldnt disengage after starting truck some times. last time it smoked the cable from alt. to battery ground. is the starter mounted on pass. side of trans. this is on a 1987 f-150 lariat automatic/ w/c6 trans.
Old Sep 4, 2005 | 08:55 PM
Popa Tim's Avatar
Popa Tim
Yes, the starters typically mounted on the rear passenger side of the engine.
Which engine do you have in it?
Welcome to Ford-Trucks too!
Popa Tim
Old Sep 4, 2005 | 09:00 PM
ford390gashog's Avatar
ford390gashog
well what you described is not the starter it is the starter relay on the fender.
Old Sep 4, 2005 | 09:54 PM
MRL123's Avatar
MRL123
I gotta go with 390 on this one - at least to start the troubleshooting process. It sounds to me like the relay is not releasing - the contacts are sticking together. I would start with the relay and replace it with a new one or at least a known good working one and see if that fixes the problem. At this point in time it would probably be worth your while to replace or at least clean up all of you battery connections at the battery, starter, relay etc.
Cheers!
Mike
Old Sep 6, 2005 | 08:33 PM
wagiles's Avatar
wagiles
starter prob.
thanks guys it turned out to be the starter (1987 f-150, 302v8 w/c6 tranny) mounted on front of tranny pass. side thanks again....
bullnose1985
20
May 21, 2021 07:27 PM
northernguy
1983 - 2012 Ranger & B-Series
Nov 14, 2011 05:38 AM
berlincam86
33
Feb 27, 2011 07:16 PM
merlin4044
27
Oct 29, 2003 07:28 AM
oft
Jun 11, 2001 06:20 AM
