conversion chart
Old Sep 5, 2005 | 07:40 AM
RockyTopFord's Avatar
RockyTopFord
conversion chart
I searched for a thread concerning a certification label conversion chart for info about my truck..but I couldn't find one. Might someone out there point me in the right direction? Thanks..<img>
Old Sep 6, 2005 | 08:52 AM
RockyTopFord
Well, we had no takers for this question, so maybe I should re-post in a different manner. The conversion chart tells what the codes mean that are listed on the data plate located on the driver's side door pillar. I'm looking specifically for the reference to third member gear ratio, exterior paint codes, interior trim and seat codes, and suspension id codes (rear). Thanks...
Old Sep 6, 2005 | 10:30 AM
subford's Avatar
subford
If you would post the numbers and letters with the spaces that are in the two lines on the tag that is bolted to the rear cover of your rear end we will try to help you.
Also you can post the code that's under AXLE on the drivers door post but it will not give as much information.
You can also list the other information codes that are on data plate located on the driver's side door pillar and we will try to do our best.
There is a site but it seems to be for only one year that it will not state and the codes do change from year to year.
Old Sep 6, 2005 | 12:35 PM
andym's Avatar
andym
They don't really change all that much. Try the tech article section, there's an article there on decoding the information.
Old Sep 6, 2005 | 08:57 PM
RockyTopFord
Thanks..
I appreciate the info...I'll check the tech article section.
__________________________________
