Tilt column update
Old Sep 4, 2005 | 04:07 PM
66f14evr's Avatar
66f14evr
Unhappy Tilt column update
Well I finnaly got the tilt into my 77 F100 2x4.The column is from a 78 F350.It all plugged in fine but I have no signal lites either side.But the 4 ways work just fine.Are there some wires that have to be bypassed.Getting ready to pull it out and junk it.Any help before I do this
Old Sep 4, 2005 | 05:11 PM
ford390gashog's Avatar
ford390gashog
why junk it? you need to pull the wheel and test for power at the turn signal switch.
Old Sep 4, 2005 | 05:14 PM
66f14evr's Avatar
66f14evr
I'll do that rite now
Old Sep 4, 2005 | 05:17 PM
ford390gashog
also check your fuses.
Old Sep 4, 2005 | 05:42 PM
66f14evr's Avatar
66f14evr
OK I replaced the fuse now I have power to the blue wire.But it does'nt matter what I do the 4 ways come on but no indicator lite are on in the dash.When I pull the 4 ways out the indicater lites work on the dash.Very PuzzledAre there any wires that have to be changed or could it be the hazard switch
Old Sep 4, 2005 | 06:20 PM
ford390gashog
send a pm to docholiday72tx he has all the steps to fix this he helped me with mine there is a few wires that may need to be changed over. i did not have to change any on mine .but ford changed so many things its hard to tell.
Old Sep 4, 2005 | 07:37 PM
66f14evr's Avatar
66f14evr
Ok thanks I wired in a whole new switch and still the same thing.Goin to give up for today.I can't do much more before it ends up in little parts every where
Old Sep 4, 2005 | 08:56 PM
66f14evr's Avatar
66f14evr
Angry
Now just to add insult to injuriey I took the truck out for a quick run around the block.And now my steering won't return.Im goin to find a big sledge hammer and fix it for good
Old Sep 4, 2005 | 08:58 PM
ford390gashog
what do you mean it won't return?
Old Sep 4, 2005 | 09:10 PM
66f14evr's Avatar
66f14evr
You know when you let go of the wheel it centers itself.Well I have to bring it back to center or I'll just keep going the way the truck is pointed.Please help before I committ myself.I PM doc and I hav'nt heard back yet
Corkwheats
WTB - Parts & other
Jan 4, 2013 11:14 PM
steve6249
Dec 28, 2012 08:35 AM
wadar1969
Nov 5, 2010 06:22 PM
fast68
Mar 4, 2010 11:27 PM
ford-nut
Feb 25, 2005 07:35 PM
