Hi i already posted about code 8 after words i retested the system...
key on engine off code 81 10 11
key on engine running code 44 33 11
thank you for any help
truck is 88 f150 2wd 351w auto trans
Hi well i redid the code check and came out with same codes i tryed it 5 times got same codes... so with 11 code being last does thAt mean i am ok???
Thanks for the help
Ya can't get a 10 in koeo or cm.
Unfortuanately you are doing something wrong, scroll down to "how to count" to see if that helps.
(edit - forgot to put in the link) http://fordfuelinjection.com/?p=13
Also, quite a few auto parts stores will scan for codes for free if you still have problems.
