help with codes
Old Sep 2, 2005 | 04:17 PM
88fordf150's Avatar
88fordf150
Question help with codes
Hi i already posted about code 8 after words i retested the system...
key on engine off code 81 10 11
key on engine running code 44 33 11
thank you for any help
truck is 88 f150 2wd 351w auto trans
Old Sep 2, 2005 | 05:32 PM
andym's Avatar
andym
I see we got past code #8.
Check your codes against this: http://fordfuelinjection.com/?p=14
But I can tell you did something wrong. 11 is system pass, you can't get 11 along with other codes.
Old Sep 3, 2005 | 02:06 PM
88fordf150's Avatar
88fordf150
Hi well i redid the code check and came out with same codes i tryed it 5 times got same codes... so with 11 code being last does thAt mean i am ok???
Thanks for the help
Old Sep 3, 2005 | 05:47 PM
Popa Tim's Avatar
Popa Tim
Ya can't get a 10 in koeo or cm.
Unfortuanately you are doing something wrong, scroll down to "how to count" to see if that helps.
(edit - forgot to put in the link)
http://fordfuelinjection.com/?p=13
Also, quite a few auto parts stores will scan for codes for free if you still have problems.
Sorry,
Popa Tim
Old Sep 3, 2005 | 05:49 PM
Popa Tim's Avatar
Popa Tim
I read that several codes readers put out a code 10 for the seperator pulse so Ignor my previous post if thats the case.
I would clear the codes and see how long it takes for any to show up again. Having none is memory is a good sign to me.
Cheers,
Popa Tim
Illbethejudge
Apr 10, 2014 04:17 AM
jason6432
1997 - 2003 F150
Dec 28, 2011 12:45 PM
demarpaint
Sep 13, 2009 07:03 PM
superford19
Jan 1, 2007 09:35 PM
Mark Kovalsky
Jan 5, 2002 07:27 PM
