trans swap
Old Aug 24, 2002 | 11:55 AM
pointbreak49's Avatar
pointbreak49
trans swap
I have a 76 f100 with a straight 6, 300 it has a 3spd trans that I want to swap for an auto. What trans will bolt up to my motor? When I get more money I would like to swap over to a v8. Also, how hard is it to to put a front suspension off of a car so I can bring it down a little bit.
Old Aug 24, 2002 | 12:43 PM
79f3504x4's Avatar
79f3504x4
trans swap
C4 is most common auto behind small blocks & sixes.Will bolt ot engine w/proper flexplate,length of driveshaft may need changed,also some sort of shifter& trans cooler needed.Lowering parts are available,why do you want car stuff on your truck?Brian
Old Aug 24, 2002 | 03:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
trans swap
The C4 will bolt up behind a 302 or 351W also. If you use the OEM mounts and pieces everything is just a bolt up. The holes in the frame etc are all there. The only problem is the driveshaft length. You may need to change rear end gears to get the most advantageous gears for a particular motor. You may also want to drop in an AOD instead of just a plain C4. If you use the <SEARCH> function you will find all kinds of info here on the subject. I know, that requires that 4-letter word "WORK" but you will find answers lots faster.
Old Aug 25, 2002 | 10:44 AM
pointbreak49
trans swap
thanks for the info, I wanted car suspension for a smoother ride, Im not big on i-beams
Old Aug 25, 2002 | 03:24 PM
rocky2's Avatar
rocky2
trans swap
I had a '79 with a 3-speed od manuel....what a terrible trans,I guess. But I used floor auto shift linkage from a old pinto when I did a conversion.
Old Aug 25, 2002 | 04:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
trans swap
I don't blame you on the suspension change, check out my profile. I am putting a 3/4T GMC suspension under the front of my F250. I wanted to keep the load ratings and the big brakes.
Old Aug 25, 2002 | 08:52 PM
pointbreak49
trans swap
thanks for the help, there is alot of pintos here so i will look into that idea
Old Aug 27, 2002 | 06:58 PM
Jermafenser's Avatar
Jermafenser
trans swap
C4 in a Pinto? I thought they used C3?
Old Aug 28, 2002 | 08:46 AM
73Custom's Avatar
73Custom
trans swap
I think it's just the linkage, not the tranny...
Marty
Old Aug 28, 2002 | 10:27 AM
theonlybull's Avatar
theonlybull
trans swap
dont' like I-beams... man i've drivin' lots of trucks and i wouldn't trade my I-beams in for anything else.. maybe it's because i tend to go off road a fair amount, haul loads, and use mine as a truck... i'd look into drop spindles. a simple way to lower it...
as for the tranny, find a used LTD 83-85 w/302 and aod... makes for a good cheap change, and it works great
Old Aug 28, 2002 | 10:31 AM
crazeejames's Avatar
crazeejames
trans swap
