360 starter flywheel help!!!!
Old Sep 1, 2005 | 08:45 PM
Fordmutttruck's Avatar
Fordmutttruck
I'm helping a friend out with a body swap between his 77 2wd and a 76 4x4 and we wanted to use the 360 and np435 trans that was in the 4x4.
The 4x4 came from a impound lot and had a bad flywheel right off the bat and a chewed up starter. The new starter and flywheel aren't meshing correctly the starter seems to be touching on the outer edge of the teeth of the flywheel and are beginning to get chewed up after only 5 starts and beginning to look like the stuff I pulled out. Both starter and flywheel were matched to the other parts removed and came up by application in the parts store computer but something just isn't right can anybody got any ideas or part numbers of original parts for this?
Old Sep 1, 2005 | 08:53 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 23, 2005 | 08:21 PM
Fordmutttruck
Anybody got any ideas on this prob?
Old Sep 24, 2005 | 12:09 AM
Hypoid's Avatar
Hypoid
Welcome to the forum!
Yeah, that part store puter has been wrong from time to time, and the PO isn't the first one to have this kind of problem. We have had a few threads about early and late flywheels having different tooth counts, try the search function.
I can't help with part #s, but here's a bump to the top.
Good luck, Mike
Old Sep 25, 2005 | 01:50 PM
bob arrington's Avatar
bob arrington
a quirk that ive seen is that sometimes an automatic starter gets installed in a manual transmission and vice versa , i know its hard to believe but its real common with som parts stores. it seems the bendix for each is a little different. sometimes its not the parts store but an inexperienced counter person
Old Sep 26, 2005 | 10:59 PM
Putt's Avatar
Putt
I seem to recall only one part number for the FE starter, it is the same auto or manual. Is it possible you have a large (390, 11 1/2") bellhousing and only a small (352,360, 11") flywheel? That would cause a problem with the tooth mesh. Try getting the bellhousing casting number and posting it here so someone can (hopefully) ID it.
Old Sep 26, 2005 | 11:13 PM
ford390gashog's Avatar
ford390gashog
the starter is the same for any fe engine.
Old Sep 26, 2005 | 11:41 PM
texans's Avatar
texans
just a thought could it be the starter needs to be shimed? GL
Scotty
Old Sep 27, 2005 | 12:08 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Shims, now that's chebby trash talk!
.....=o&o>.....
Old Sep 27, 2005 | 01:15 AM
Hypoid's Avatar
Hypoid
Shims not an FE thing.
The nose of the starter may be an issue, but that problem is more QC related than anything IMHO.
I poked around, found these threads:
https://www.ford-trucks.com/forums/s...d.php?t=353802
https://www.ford-trucks.com/forums/s...d.php?t=399824
https://www.ford-trucks.com/forums/s...d.php?t=171474
I guess I've been pretty lucky. Ford made my truck with a 360, some PO dropped in a 390. I had to replace the flywheel when I bought it. Wore out the 390, dropped in a 360 that was mated to an auto. Through all that mix-match the only time I had trouble with the starter grinding, the bell housing had loosened from the block. I think I've bought one new starter and used the one that came with the 360/auto.
Good luck, Mike
Old Sep 27, 2005 | 01:24 AM
Robar2596's Avatar
Robar2596
They do make shims for FE starters.
Old Sep 27, 2005 | 05:14 AM
IB Tim's Avatar
IB Tim
...Welcome Robar2596, to Ford Truck Enthusiasts!
Enjoy FTE....and
Old Sep 27, 2005 | 07:54 AM
thunderguns71's Avatar
thunderguns71
So what you need is a 360/390 11 inch , 184 tooth flywheel. Your supposed to be able to get those at Advance, but I was told I could only get the ring gear, probably because the guy working that day doesnt like me. So im looking for one too, but to use on my 429 instead.
Old Sep 27, 2005 | 09:13 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Ring gears are easy to replace if that's all you could find. Just a thought......
Old Sep 27, 2005 | 11:32 AM
Putt's Avatar
Putt
Here is what the parts books say- one starter is listed for ALL FE engines, auto, manual, does not matter. Prior to 65 there is a different one listed, not an issue here.
There are two manual trans ring gears listed, one fits the typical FE with the 11" clutch, part number(Carquest) FRG-184T. There is another listed for an "M" code 390(??) that is number FRG-188T. The 184 and 188 relate to the number of teeth on the ring gear, so I think the 188 would have to have a larger diameter in order to keep the same tooth pitch. I do not know if those will both fit the same flywheel, I think they will since a flywheel was also listed and the same number fit both engine codes for the 390.
The starter shims listed for the FE do not affect how deep the tooth contact is, they are used if the nose of the starter has been machined in rebuilding enough to allow the cover of the starter drive to contact the face of the ring gear. Picture how the shim would move the starter and you will see what I mean.
HTH
