I have a simple question here
Old Mar 10, 2005 | 12:15 PM
82f1504x4's Avatar
82f1504x4
I was just wondering if all the FE starters are the same. I assume they are but would like to know for sure.
Thanks,
Justin
Old Mar 10, 2005 | 02:06 PM
82f1504x4's Avatar
82f1504x4
do you guys really not know? I thought this was the FE forum
Old Mar 10, 2005 | 02:16 PM
gbrett's Avatar
gbrett
as far as i know they are if there is a different starter it would most likly be for the 410 and 428 because they use a different flywheel
Old Mar 10, 2005 | 02:30 PM
ford390gashog's Avatar
ford390gashog
they all use the same the 410 and 428 all use the same flexplate or flywheel the starters are the same for either a manual or a auto tranny
Old Mar 10, 2005 | 03:22 PM
bertha66's Avatar
bertha66
The older FE's, as in my 64 Galexie and 63 T-Bird had a reverse pull starter and differant gear ratio. I think this changed in 1966 or 1965. The reverse pull type have a long shaft and bendix drivethat goes behind the flywheel and is pulled back into the flywheel when engaged.
Old Mar 10, 2005 | 06:11 PM
76supercab2's Avatar
76supercab2
You really expecting an answer in less than 2 hours? As always it depends on who's on-line.
Old Mar 10, 2005 | 07:27 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
And to add to what bertha66 said the early type of starter also had a slightly different bellhousing to house the longer starter. I use an old M/T bellhousing with one of these longer "folo-thru" starter drives. G.
Old Mar 10, 2005 | 09:08 PM
bertha66's Avatar
bertha66
On my 64 I used the old stile bellhousing with a newer flywheel and newer starter. the newer starter will bolt to the old type of bellhousing if you change the flywheel.
Old Mar 12, 2005 | 01:39 AM
82f1504x4's Avatar
82f1504x4
thanks, thats all I needed to know
Old Mar 12, 2005 | 07:10 AM
Lazy Hog Farmer's Avatar
Lazy Hog Farmer
There may be one other thing that you need to know. Take your old starter with you if you have one to compare with the new. I bought one once that laid up in the bell housing just fine but would not rotate enough to line up the three bolt holes. It took me a while to figure out that the nose or housing around the drive gear was hitting the flywheel. I took it back to NAPA and they found one that worked, I could have ground some off with the same effect but I thought they had given me the wrong one. Steve
Old Mar 12, 2005 | 10:10 PM
dinosaurfan's Avatar
dinosaurfan
starters
82, no they are not all the same. there are at least three differant styles. The earlier ones (65 ? and older ) are differant than the newer ones, and the manual and auto tranny equipped trucks take differant part numbers. The actual starter motors are the same, but the drive and the aluminum noses are differant. Mix them up and you'll know. If your getting a new ( or rebuilt ) starter, don't give the parts store your old one untill the new one is in there and you know it works properly. I have worked at a parts counter before, and those books have plenty of mistakes in them. Compare the new with the old very carefully. Remeber that old carpenter's saying...'measure twice, cut once' DF, @ his Dad's house
12gaugeCharlee
New Member Introductions
Jan 24, 2018 10:05 PM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
