Running Your Rig on Propane/LPG?
Old Sep 1, 2005 | 08:10 AM
VirginiaWiFinder's Avatar
VirginiaWiFinder
Ok,
With the cost of gas going out of control something's gotta give and I really don't want it to be my truck. (Gas here is $2.85 in Central Virginia, $3.01 at my brother's house in NC, and $3.40 at the in-laws in <st1:city w:st="on"><st1 ="">Baltimore</st1></st1:city>, and more out west!) So, in thinking and poking around it looks like propane/lpg is the best alternative fuel source. It looks like a straight out swap, especially since there are lots of vehicles on the road using propane (such as many Municipal vehicles, Canadian vehicles). Propane is much cheaper than gas, right now it is around $1.50 a gal. Also propane runs so much cleaner and gas mileage is supposedly just slightly less than gas. The cleaner burning engine is also lasts much, much longer from what I've read.
So is anyone out there running propane on your 67-72? If so what setup are you using and how good or bad has it been for you? And....if you have a dual fuel setup are not using it....please feel free to PM and maybe I can get that off of your hands.
Old Sep 1, 2005 | 08:46 PM
Ford_Six's Avatar
Ford_Six
The big things about propane is that it burns really hot, and it's dry. You need to have stainless valves, or at very least one-piece valves if you have an FE, the extra heat will make the stock two piece valves snap. You can't run it without hardened seats, either, or the valves will sink into the heads in a matter of months. You should run diesel oil, or a very good 10w40 synthetic to prevent upper cylinder damage too. The fun about propane is that you can run high compression, 12:1 would be easy with propane with the proper spark timing. IIRC propane is about 130 octane, so you can make up the lower btu's per gallon with a higher compression, leaner burning engine to get the same or maybe a little better mileage.
Old Sep 1, 2005 | 11:03 PM
GLR's Avatar
GLR
Local propane dealer here in NY converts all his trucks to propane, no interior mods done to engine, and they run over 400,000 miles. Carb conversion costs about $1000, runs on propane only. EFI runs around $2000 with special injectors vehicle is started on gasolene then switched over to prop. You can go back and forth with a flip of the switch.
Old Sep 1, 2005 | 11:12 PM
ford390gashog's Avatar
ford390gashog
no. propane is 110 octane it does not burn really hot. you don't need special valves at all. with a octane rating of 110 it will burn slow. where did you find this info??
the propane setup is easy to do. check out my post in the alternative fuel section.
Old Sep 2, 2005 | 01:30 AM
Ford_Six's Avatar
Ford_Six
I'm working off the damage I have seen to OHV Forklift engines run off propane, and what I have seen on trucks run primarily on propane.
Where I am working, we have an 00 Hyster, the thing is a gutless wonder so service got called, compression test came back as 83-80-95-91, oil brought them all up to the 130 range. I'm pulling the engine in the next few weeks to rebuild it, I'll have a better idea of the damage then.
Most stock replacement valves for gasoline engines will say, not for use with propane. They overheat, stretch, and if it's a stellite head welded to a stainless stem like stock Ford valves, they can break at the weld.
PaulsEdge
Alternative Fuels, Hybrids & Mileage
Jan 9, 2017 07:09 AM
munts77
Aug 30, 2012 07:23 AM
E350superduty
Modular V10 (6.8l)
18
Aug 24, 2005 09:26 AM
gingerbreadmaniac
Apr 23, 2005 01:39 AM
