how to fix myself
I've worked on cars for over 15 years.. never damaged a starter by doing this... but I've never beath the heck out of them either. If light to moderate tapping doesn't do the trick, then beating it won't either.
As far as starters goes... the NEW type starters have a permanent magnet setup... you can usually identify them by having smaller housings and weigh much less than traditional starters.
Step one: Jiggle the battery cables. I am not kidding here. I can't tell you how many time I've seen somebody throw perfectly good equipment away when all that was wrong was a battery connection. Turn the Key to on, and leave the keys in the truck ignition and the door open. The door bell should ring. If it does not, jiggle the wires. If it does not ring after this, then take the positive battery cable (the one corresponding to the plus sign on the battery) and check it's connection to the battery. Is there any corrosion? Is there any dried up battery acid? If so clean it with baking soda in water and try again. If it still does not ring then you have a dead battery. Replace or charge before seep two.
Step two: obtain a set of jumper cables DO NOT USE ANY OLD WIRE!! there are a lot of amps involved here and we can't be setting anything on fire because you have speaker wire laying around. That said
Step three: Find the positive battery cable. This will be the one with the plus sign on the battery, and will usually be red.
Step four: follow the positive battery cable. Take your had and from the battery run it along the length of the positive cable to see where it goes. The first thing you will come to is the starter selenoid. Then the starter. These may be really close together, but the wire should go from the battery to the selenoid.
Step five: testing the selenoid. There should be two large posts on the object that the large wire from the battery goes to the other post should correspond to a wire that goes to the starter (see next step for starter description). Turn the car's switch to on ( not start, but where the key will rest when you try to start and let go of the key) then crawl under the truck and take a screwdriver and cross these two large posts. If the truck starts, then you have a bad selenoid. WARNING: this is a dangerous step. There will be sparks if the battery is good, and the motor will turn over if the selenoid is bad. This means that any part of you in the way of moving parts of the motor will get hurt, so make sure that you are as out of the way as you can be.
Step six: Testing the starter. If the starter refuses to Jump or even budge the motor on step five then do this, trace the wire from the big post on the selenoid that the battery cable IS NOT connected to to the starter. This should be a big round cylinder about four to six inches in diameter and six to ten inches long. Connect the Jumper cables in step two to where the wire from the selenoid connects, then run this Jumper wire to the Battery and connect to the positive side of the battery and see if the Motor turns over. If it does not and all of your connections were clean and you are sure that you battery is a good one than the starter needs replaced. If the starter does turn the motor over, then you have a bad connection somewhere.
Tell me how it goes, and I apologize in advance if I don't answer back right away, I'm kinda busy right now. I can tell you how to replace a starter, but this can be a little tricky depending on the location of the starter.
I'm not sure where the other engines are.. I think they are in the same place.
Check the small wire going to the start.. not the large one. This is the solenoid wire... when you turn the key to start this wired is powered up by the relay and it engages the starter solenoid, which in turn engages the starter.
Sometimes the connection of this small wire, being such a small wire, can corrode or vibrate loose from the starter itself... Try jiggling it a little, but not too much as it may break off. Look for corrosion at the connection and if you have test light you can probe it while someone holds the key on start (make sure it's in park or neutral so incase it does crank you don't get run over). If you have power there then the problem is likely in the starter itself or the large starter power wire.
It's rare there's a problem with the large main power wire, and when there is a problem it's usually up at the battery terminal, but anything's possible.
Another possibility is the starter relay... I believe they've pretty much moved this into the underhood fuse box... just remove the cover and they are usually squares, about an inch in diameter... try LIGHTLY tapping these.. might try removing and reinstalling.. sometimes you get a little bit of corrosion causing a bad connection.
Might also try swapping relays around, as you probably have 3 or 4 for different things and they are usually the same exact part, however if you have a bad relay keep in mind whatever the other relay powers up may not work.
Hope this helps.. good luck
I can only add this:
BEFORE you do any work on this truck, chock the wheels and make sure the truck is either in 'Park' (auto tranny) or 'Neutral' (manual tranny) and get that parking brake on!
(You don't want that truck to start rolling IF it starts for you!)
Other than that. . . amish77 has given you some fantastic advise!!!!!
That manual seems like a good investment overall. A 92 truck isn't gonna have just one problem during you're ownership of it unfortunatley.
Good luck and welcome to the club.
) and the directions break it down pretty well. I'd say do what amish77 recommends first though anyway, since you probably have the tools necessary for that anyway. Good luck and let us know how it goes!
