the difference
Old Aug 30, 2002 | 10:30 PM
Brassmonkey_83's Avatar
Brassmonkey_83
the difference
I would like to know what the difference is betwen the 73 f100 exlporer and a 73 f100 ranger. This is just a curiocity question. I am also having alot of problems out of my 73 f100 its has a 302 monted to a c4 trany. My prob is it ran fine up till i put a distributer in it after the fuel lines cloged (wich i fixed) and a new fuel pump and carb rebuild if it does start it lacks alot of power i also have the timing set right. I would greatly apriciat any help. (pardon the spelling)
Old Aug 30, 2002 | 10:37 PM
Mil1ion's Avatar
Mil1ion
the difference
The Explorer is just a trim package.
Upolstery,Carpeting,Headliner,Emblems.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 30, 2002 | 10:38 PM
LxMan1's Avatar
LxMan1
the difference
The exhaust isn't clogging up is it? Still sounds like a timing issue to me. Maybe the advance isn't hooked up right.
The ranger and explorer were just different trim packages I believe. I don't know the exact details though. I Know that the Ranger's had more options than the customs usually.
Old Aug 30, 2002 | 11:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
the difference
The Explorer was the top of the line trim package.
Check your engine vacuum level. It is a key indicator of an engine's general condition. It will tell you if the timing and mixture is right. It will also tell you the condition of the valve train.
Old Aug 31, 2002 | 02:39 AM
Mauser8mm's Avatar
Mauser8mm
the difference
Are you sure you rebuilt the carb correctly?Also check to make sure you air/fuel mix is correct. Sounds like it may be running a bit lean. Cood Luck!
1979 F-150 4x4 351M C-6 NP205
2001 Ranger XL
Old Sep 1, 2002 | 06:54 PM
slick78's Avatar
slick78
the difference
Old Sep 1, 2002 | 08:12 PM
jbulson's Avatar
jbulson
the difference
double check you plug wires too...maybe you have a couple swiched..
Old Sep 1, 2002 | 09:10 PM
71swissaqua's Avatar
71swissaqua
the difference
I once bought a new distributor and could never get it to run right. Finally checked the vacuum advance. The rebuilder had turned the adjustment screw all the way in. Started adjusting on it and straightened it out. Something to check.
Clint
Wookie302
Feb 14, 2013 06:32 PM
73FOMO
Aug 15, 2012 09:05 PM
evan.kelly978
Jun 12, 2012 10:18 AM
knibbeone
Sep 18, 2009 05:41 AM
mike
Jan 10, 2000 09:57 PM
