Clutch/ Slave cylinder
Old Aug 31, 2005 | 12:06 PM
Badfish1060's Avatar
Badfish1060
Clutch was getting stuck on the floor, but when I pull up on it, it releases. It will work for 5 or 6 pumps, and then it is almost like it gets sucked to the floor.
When I checked the fluid it was slightly low, I have sinced filled it up, same issue.
2000 f-250 7.3L 160k 2wd
TIA
Old Aug 31, 2005 | 01:25 PM
profro's Avatar
profro
I had to replace my clutch slave kit. I thought it was common that they became real mushy and had low engagement and eventually needed to be replaced. I bought the kit (complete and pre-bled) from Ford for about $100 and installed it in about 30 minutes. Pretty simple. You might want to just change the whole thing out.
Old Aug 31, 2005 | 09:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I believe that is Badfish's problem as well. Ford part # 2c3z-7c522-CA
Thomas lee
Oct 20, 2014 11:00 AM
Gettysburg150
24
Jan 4, 2014 09:05 PM
phoneman91
Feb 24, 2012 01:48 AM
Mulletwagon
1978 - 1996 Big Bronco
Jan 2, 2001 11:34 PM
