computer codes?
Old Aug 30, 2005 | 07:43 PM
ranger67's Avatar
ranger67
computer codes?
hello, i have a 2001 ranger edge 4*4 and it just threw a po171 & po174 code, i have checked all the vacume lines and egr valve (with a vacum pump) and looked at the maf sensor (which doesnt appear to be dirty) i also have checked the iacv valve and it is working properly. and i still have the light(check engine) and the problem. what do i need to check now? thank you, grant.
Old Aug 30, 2005 | 08:13 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 30, 2005 | 08:53 PM
Ken00's Avatar
Ken00
Low fuel pressure could cause both banks to be lean. Also if you have a 4.0 they have intake manifold vacuum leaks and that could cause it too.
Old Aug 31, 2005 | 05:50 AM
ranger67's Avatar
ranger67
thanks for the reply, ill check out the manifold, hope thats it.
Old Sep 1, 2005 | 08:43 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Also check the PCV valve.. make sure its seated properly in the grommet.. i've seen quite a few come out.. even a couple "cracked" valves.
They are pretty cheap.. usually under ten bucks.. might as well throw a new one in there while you're at it.
Other possibilites = putting ethanol (E85) in a non flex-fuel vehicle
Low fuel pressure and/or volume
Intake leaks (as previously mentioned)
Poor fuel quality
