hello, i have a 2001 ranger edge 4*4 and it just threw a po171 & po174 code, i have checked all the vacume lines and egr valve (with a vacum pump) and looked at the maf sensor (which doesnt appear to be dirty) i also have checked the iacv valve and it is working properly. and i still have the light(check engine) and the problem. what do i need to check now? thank you, grant.
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
