EBP Sensor Replacement
Old Aug 30, 2005 | 05:38 PM
lpbaca's Avatar
lpbaca
There is alot of discussion regarding loss of power and black smoke which I am experiecing now. Is the EBP sensor easy to replace and inexpensive and will it cause any problems to the computer if replaced? I have a hard time working with the dealer when discussing this issue. My truck is a 03 6.0l w/26k miles.
Old Aug 31, 2005 | 05:41 AM
Ford_Doctor's Avatar
Ford_Doctor
To answer your question, the EBP sensor on an F-Series is fairly easy to get to and I think it lists for about $160.00.
To give you some advice, I don't think your problem is the EBP sensor. From your description, my professional Internet guess is that your EGR valve is hanging-up on you. A lack of power and black smoke, sometimes described as "billowing" is the classic description given by many of my customers. In most cases, the valve is the cause.
Old Aug 31, 2005 | 11:08 AM
Forest's Avatar
Forest
Ford_doctor,
Is there a special tool for removing EGR valve. If so, where can it be purchased?
Old Aug 31, 2005 | 11:16 AM
Ford_Doctor
There is a special tool, it doesn't work so forget that idea. Remove the two retaining bolts, use a screwdriver to rotate the valve in the bore to expose the ears. Using two pinch bars/ lady finger pry bars under each ear, gently pry it loose and out. Replace it or service it as required and be sure to follow the other information I sent you.
Old Aug 31, 2005 | 02:40 PM
Forest's Avatar
Forest
Hey, thanks. I appreciate the info.
Old Aug 31, 2005 | 02:47 PM
ryaneverk2's Avatar
ryaneverk2
Do you think one of you could post the Info here for all to benefit from?
Old Aug 31, 2005 | 06:55 PM
Ford_Doctor
I would but this information is published on my web site. My posting links to it makes the Webmaster unhappy so I no longer will out of respect to the site owners.
Cell's
Apr 3, 2022 10:56 PM
Iaff113
Sep 11, 2014 01:58 AM
99powerstrokeSD
Jul 3, 2007 09:38 AM
eric777
Aug 11, 2006 01:01 PM
TIM PADGETT
Jun 10, 2005 07:43 AM
