Oil Drain Plug?
Old Aug 31, 2005 | 08:59 PM
gp42gpw's Avatar
gp42gpw
Question Oil Drain Plug?
I plan on doing my first oil change this weekend and this is probably a silly question and I should just give it a one grunt tighten but does anyone have the drain plug torque number (I don't want to strip it)? I looked in the tech section but can't find the plug just the filter cap.
Thanks in advance
Glen
05 F-350 4x4 Reg Cab PSD 6Spd.
Old Aug 31, 2005 | 09:30 PM
Ford_Doctor's Avatar
Ford_Doctor
Most people just wipe it clean and snug it up but if you insist on being precise the specification is:
  • 18 Lb/Ft
  • 25 Nm
By the way, I have no problem with people torquing an oil drain plug, I am just not used to any one asking! At least it means you care enough to want to avoid damaging the threads.
Old Aug 31, 2005 | 09:42 PM
gp42gpw's Avatar
gp42gpw
Thanks Ford_Doctor I know it's **** but I figured while I had the torque wrench out to do the filter cap why not do the plug the right way.
Thanks again
Glen
Old Aug 31, 2005 | 10:23 PM
whalerron's Avatar
whalerron
Make sure you torque the oil filter housing cap too. It's a plastic cap and you don't want to break it. You can torque it to 18 ft/lbs too.
