engine comparment
Old Aug 31, 2005 | 05:43 PM
B/B ford's Avatar
B/B ford
Clean & Classy
AX,That is what I did when I cut out the cross braces to move condenser closer to the radiator, it flexed too much so I used a piece of 1/4 20 allthread . Its under the the radiator valance so you can't see it.
Old Aug 31, 2005 | 10:09 PM
robodog562000's Avatar
robodog562000
I looked at the pics of your f-100's, they are awsome. I don't think I'm going to modify the sheet metal a whole lot. It's alot of work. Tilt looks pretty cool. You guys have done alot of cool things with your trucks.
Old Sep 1, 2005 | 12:59 PM
Phity Five's Avatar
Phity Five
What might be kinda trick is double nut (or similar means) one end of the rod, so that it can swivel/pivot out of the way when you want to work on the motor and such. The other end could be fixed with something similar to a hood pin and cotter.
Brian
Old Sep 1, 2005 | 01:38 PM
AXracer's Avatar
AXracer
threaded clevis on each end.
Old Sep 1, 2005 | 11:00 PM
fatfenders56's Avatar
fatfenders56
one l/h thread, one r/h, easy to adjust
