6.0l PSD Oil Thread
http://eolcs.api.org/FindBrandByServ...eCategory=CJ-4
With so many "officially certified"... not sure why anyone would use a non API certified/registered oil in their expensive diesel motors... but they do...
Everyone pretty much swears by syn due to the cold up here. If it was only for a month or so that would be a different story.
...I guess it's ok, but IMO any product you can get at a big box store has to be just another oil. Look at the truck stops, the trucker's mags, do some research to see what the big guys are using. Cross refernce the Cat, Cumapart, and Navistar specs with Ford's PSD specs and find the product that meets Ford's and the majority of the others' specs. Why? Those are the products that will be most available because they're used by more people in the diesel using industry. Maybe even get your oil there.Another suggestion: find an owner operator who takes good care of his equipment and pick his brain a bit. There are brands of oil the average guy never hears about because these companies don't waste their money on advertising, but put it in their products, R&D, and customer service.
To name a few: Central Petroleum Company (Cen-Pe-Co), Schaeffer Manufacturing Company (Schaeffer Oil), and Texas Refinery Corproation (TRC). (I have seen some Schaeffer ads.) I have used the products of one of these for years, but have never seen much commercial advertisement from them (I have seen some Schaeffer ads). The products are not cheap, but reliable and I never worry if I happen to need to go over the O.C. interval by a thousand miles before I can do it. I can get free analysis anytime I want to send in a sample. I don't run a diesel now, but when I did, I bought my oil from a part-time Owner Operator/farmer out of his drum.
Just remember, the oil HAS to be engineered for diesel engines and carry the API mark for the recommendations of your engine...and the recommendations have changed rapidly over the past few years, so much so, that I haven't even tried to keep up with them. What I do know is that your diesel engine oil must be able to neutralize sulfuric acid and a gasoline engine oil will not do that well. That's why you want an oil with a high TBN (total base number) like 14 or 15. The chemical base neutralizes the acids formed in the crankcase and keeps all that junk suspended until drain time.
Back to the cross-referencing theme: I was able to cross reference a Massey spec. for transmission/hydraulic fluid and found the John Deere "303" transmission/hydraulic fluid satisfied the same mil. spec., but Massey would never tell you that
. Then I found the "JD 303" recommended fluid from one of the three companies mentioned above and that it surpassed the JD 303 specs. The bonus was it was a lower price than the Massey labeled product. So a little work
paid off.Added kicker was that the Massey trans ran a bunch cooler
on the better fluid when plowing and discing...so much so that you could feel the temperature difference. You guys that ever ran a smaller tractor know what I mean...like, where is that transmission located, exactly? Yep, right between your legs!
and need 0W or 5W oil, here is the CI-4 listhttp://eolcs.api.org/FindBrandByServ...eCategory=CI-4
Try and stay warm
PS Thanks for the list. Now I have other choices to chose from. Just have to use up the 12 gallons that I bought before I run out.
Here is a link to API explaining the differences in each oil rating category.
www.apicj-4.org/EngineOilGuide2006.pdf
Currently none of the oil manufactures have an API "certified" CJ-4 synthetic oil. I am guessing that it is just a matter of production roll out based on what oil sells the most being released first.
Hope this helps
It is only available at this time as a 15W-40 oil... so maybe too thick for you in Alaska. I would stick with Rotella-Syn 5W-40 until they, or the other brands release a synth. version of the new CJ4 API spec.
You local Walmart can order the Rotella for you as it is an "approved item" for them... just someone is too lazy to order and stock on the shelves.
10W-30 will make for easier starts and will give you the CJ4 protection you desire. Let us know how it performs.
Citgo makes an oil called Citgo - Citgaurd "syndurance" Synthetic 5W-40. Be careful becuase there is a synthetic blend 5W-40 available too... so make sure you get the 100% synthetic version!!!
The PDF file/link below has the info about the oil and there is a toll-free number to call to find dealers in your area. I was given two names and only one can order it for me in gallon jugs.
http://www.docs.citgo.com/msds_pi/465116.pdf
http://www.forester.net/mw_news_031006_citgo.html
The price I was quoted was $21.00/gallon and they have to get back to me on Monday about ordering it. This formulation is a PAO "true synthetic" like Mobil 1 oils are... which is slightly different than the Group III synthetics that Rotella markets. Both meet API certifications for CJ4... but this is the first oil I have seen in synthetic 5W-40 weight that is also CJ4 spec'd!!!!! I already use Rotella-Syn and buy it at Walmart for roughly $18.00/gallon.. the the few extra dollars is no big deal to me and I get CJ4 spec'd oil!!!
Before anyone adds tho this thread about Chavez and his comments at the UN about President Bush (which I find horrible)... I have no problem buying the weight and type of oil from Citgo since I have no other choice at this time... if Mobil, Chevron or Rotella would launch their synthetic version of CJ4 oil.... then I would buy it first... but until then... I will place my order for 5 gallons next week
