Oil & Lubrication
6.0l PSD Oil Thread
Old Nov 14, 2006 | 05:08 PM
  #31
mrxlh's Avatar
mrxlh
Captkirk, just adding to the info that Blackhat has stated, 5000 mile oil change interval should be reguarded as max, period end of paragraph. The hpop that uses high pressure oil to fire the injectors along with other internal components of the 6.0 shear the oil weight from 40 to 30 pretty quickly. There has been several TSB's reguarding this along with proper oil level (many people overfill) creating a vast number of drivability issues with these trucks.
If you want to increase your O.C.I. I highly recommend using a GP IV synthetic and very careful oil analysis. General concensus is running conventional oil til 10,000 miles before switching to synthetic, I changed at 5,000, but it was a GP III syn (5W40 Rotella T) with no ill effects ( 32,500 miles, only thing that gave me problems so far is the paint peeling off the F250 emblems, and the oil dipstick broke at the top where it seals to the dipstick tube. Knock on wood.
Old Nov 14, 2006 | 11:45 PM
  #32
captkirk9195's Avatar
captkirk9195
OK.. sounds like my plans for 5K/6 months and synth should be enough to make the truck last well (and probably, dramatically overkill). I tend to change the oil more from age than mileage on most vehicles, as I don't commute to work anymore so the truck ONLY will be towing back/forth to the racetrack (70 miles each way through mild hills) 2-3 times a month from Feb to Oct.
Over the winter, it's drive it occasionally to keep the moisture out, and the seals wet. And with a truck, drive it if we get HEAVY snow and need to go somewhere. They seem to get the streets clean so quickly here that even an 18" snowfall is clear in 2 days.
Truck came home with me tonight. '03 F250 XLT CC 6.0 PSD FX4 4x4 (wow, too many designations, I'm sure I left some off :P)
29K on the odometer. Only major work it has needed at the dealer was a mirror replaced. Other than that, it has a flawless record.
Time to go download a service manual from the ford site for my "new" truck.
Thanks again,
Jason
Old Nov 15, 2006 | 12:05 AM
  #33
blackhat620's Avatar
blackhat620
captkirk9195,
You need to take your truck out once a week (not less than every other week worst case) and drive it like you stole it. The VV Turbo in these trucks will rust the blades in position if it is not driven enough, even if it is kept in a garage. These trucks like to be exercised or they tend to act up. Also make sure you are using a good fuel additive like Diesel Kleen or Stanadyne. Especially since the truck sits around with fuel in it for long periods of time. Diesel fuel does not like to sit around.
www.powerservice.com/dieselkleen_cetane.asp
www.stanadyne.com/new/ppt/showfile.asp?id=3384
My advice is to take this truck out one day a week for a nice 1-hour or so drive, it will keep the truck in good shape and let you clear your mind while you are racing down the highway.
Hope this helps
Old Nov 15, 2006 | 12:23 AM
  #34
captkirk9195
Yeah I was figuring I'd take it out about once a week to do exactly as you suggested. Maybe only 30-45 min, but enough to warm it up, and top off the tank if it's below 3/4 to keep the moisture out. Yeah.. used to conventional turbos (old race car) that didn't have an issue with sitting for weeks at a time.
Jason
Old Nov 15, 2006 | 12:35 AM
  #35
mlb4966's Avatar
mlb4966
I love my 5w40 when its cold. I mean when you wiz it freezes as it hits the ground, you eyelashed fall off when trying to open you eyes, well you get the point. MY question is WHO ELSE carries Rotella T since our Wally World hasnt had it for the past 4 months....
PS A heat wave is anything above 70......at least in my neck of the woods.
Thanks
Old Nov 15, 2006 | 12:51 AM
  #36
blackhat620
mlb4966,
Here is a link showing the Rotella distributors in Alaska, call them and see who carries it in your area.
http://www.rotella.com/wheretobuy/di...s.php?state=AK
Hope this helps
Old Nov 18, 2006 | 08:38 PM
  #37
member33094's Avatar
member33094
How about oil filters for the 6.0? The oil guard website has oil fiters for only $10 they look just like the ones from the ford dealer. Is the savings worthwile?
Old Nov 18, 2006 | 10:26 PM
  #38
blackhat620
No! They are not the Racor filters, they are "will fit" copies that try to circumvent the Racor patent, and the can damage your engine. Use only Racor filters get Motorcraft,, International or believe it or not Fram licenses the Racor filters and puts them in a Fram box.
The filters will be made in Germany or USA and have the patent number stamped on them.
Hope this helps
Old Nov 19, 2006 | 10:19 AM
  #39
member33094
Thanks blackhat.
Old Nov 20, 2006 | 08:23 PM
  #40
firesoutmatt's Avatar
firesoutmatt
Blackhat is usally spot on .
Old Nov 21, 2006 | 10:40 PM
  #41
woodys06's Avatar
woodys06
Originally Posted by blackhat620
Shell Rotella 5W-40 Synthetic and Mobil 5W-40 Delvac 1 or Turbo Diesel Truck(same as Delvac 1, just different package) are API CI-4+ certified, and Delo 400 Synthetic 5W-40 is API CI-4 certified. I prefer the CI-4+ certified oil as it works better in motors containing and EGR system.
Hope this helps
Delo 400 15w-40 is also CI-4 Plus certified. Also states its been "Formulated for ULSD and high sulfur diesel fuels."
Miles
Old Nov 21, 2006 | 11:02 PM
  #42
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Miles
CI4+ oils are backwards compatible... but if one owns a new MY 2008 truck or the new 6.4L PSD motor.. then you can ONLY use CJ4 oil and ULSD fuel (15ppm).
CI4+ works with all fuel as long as it is the 6.0L , 7.3L or older diesel motors... just not the new 6.4L PSD motor.
Old Nov 21, 2006 | 11:55 PM
  #43
blackhat620
Miles
Yes Delo 400 15W-40 is CI-4+ certified dino, But it is not Synthetic and the poster specifically asked for Synthetic oils.
Hope this helps
Old Nov 22, 2006 | 12:19 AM
  #44
mlb4966's Avatar
mlb4966
mlb4966,
Hope this helps
Figures only 3 and they are all a 12 hr drive (RT).
Old Nov 23, 2006 | 01:04 PM
  #45
blackhat620
Here is a link to a listing of all the currently API "certified" CJ-4 oils available around the world.
http://eolcs.api.org/FindBrandByServ...eCategory=CJ-4
