Sponsored by: Real Truck
Keyless entry
Old Aug 30, 2005 | 08:36 AM
MCPOUSNRET's Avatar
MCPOUSNRET
Keyless entry
FTE Family....Does anyone else notice that you have to get very close to your truck in order to get it to unlock with the keyless entry? I have replaced the battery in the sending unit. Any fixes that you know of?
Old Aug 30, 2005 | 08:51 AM
69cj's Avatar
69cj
What do you consider close? I usually use mine between 15 and 50 feet with no problems.
Old Aug 30, 2005 | 08:55 AM
MCPOUSNRET's Avatar
MCPOUSNRET
50 feet.....No way. I would say 8 ft. I was able to open my 2003 F-150 4X4 supercrew FX4 from 150 feet ( guess). It was quite away while in a wal mart parking lot.
Old Aug 30, 2005 | 09:38 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Do you have tinted windows etc??
There are "dead spots" within the recievers band. All keyless entry systems have them. Try walking around the truck at different angles, and see if there are only specific areas where it "won't open" at a certain distance.
Beyond that, it could be a faulty keyless entry module.
Old Aug 30, 2005 | 03:40 PM
function12's Avatar
function12
I have the same problem. Close for me, is standing right next to the door. It takes 4-5 presses to get all doors to open when it should only take 2.
My windows are tinted too.
Old Aug 30, 2005 | 11:24 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
I have a new 06 F350. Mine works from 30 ft easy.
Old Aug 30, 2005 | 11:36 PM
vfrrick's Avatar
vfrrick
I have a 2000 and finally just put an alarm on it so I could get away from the ford keyless system.
Old Aug 30, 2005 | 11:40 PM
KarenLynnAQHA's Avatar
KarenLynnAQHA
Yep same here. I could open my '01 WAYYYYY farther back than i can my new '06. It seems like the keyless entry is not working well for me at all. I can get it to unlock the front just fine but it takes me hitting the open key several times to get the rear doors open. My old truck you hit once for fronts and twice for rears like clockwork.
Old Aug 31, 2005 | 09:26 PM
Chris_in_Texas's Avatar
Chris_in_Texas
Speaking of keyless entry system... Where is the control box in the 2005's?
Thanks,
Chris
Old Aug 31, 2005 | 10:04 PM
Antacus's Avatar
Antacus
Put it under your chin when you unlock it... works from 3x as far away
Old Sep 1, 2005 | 07:52 AM
lg3rd's Avatar
lg3rd
The chin thing does work but why??? Soome have speculated that the antenna is directional and holding it vertically increases range. Some think that using your head as a booster antenna does it but holding it up over your head also works.
Anyway, 8 ft. max. tells me something isn't right. try the other remote that came with the truck. if this does the same thing, the receiver in the truck may be causing the trouble.
Old Nov 18, 2005 | 10:19 PM
93Miata's Avatar
93Miata
Some just wear out with use, not battery related.
I was looking for replacement keyless entry remotes not too long ago and I found a site that had them for $24.99 NEW for my F-150.
I had them delivered in less than a week and the programming instructions only took maybe 10 seconds?
Anyways, here's a link to the site:
Https://www.ThePartsYouNeed.com
Just click the Ford category, or type F-250 or F-350 in their search box.
Old Nov 19, 2005 | 02:17 AM
biz4two's Avatar
biz4two
Great info 93miata! I added to my favorites...for future reference.
Thanks for providing the link...
biz
