hubs wont turn
Old Aug 30, 2005 | 12:33 AM
riley42204's Avatar
riley42204
hubs wont turn
I have a 02 4x4 7.3 and my auto hubs are stuck in the auto position. I have tried turning them with pliers to lock with no luck. Is this a common problem, do I need to get new hubs? Thanks for the help.
Old Aug 30, 2005 | 03:13 AM
Scruffy's Avatar
Scruffy
I have an 01 4x4 7.3 my drivers side was hard to turn. So hard it hurt my fingers to turn it by hand but I was afraid of breaking the plastic using pliers. Oopps there that plastic again on a truck. So when my bearings went out I took my hub apart, as far as it comes apart and sprayed it down with brake cleaner and then sprayed it down with oil. It seemed to help but still isn't as easy as the right side. With mine though the problem is in the hub itself, just doesn't have a smooth turn.
Old Aug 30, 2005 | 08:33 AM
SBFD8's Avatar
SBFD8
Mine did the same thing. Ford does not sell a rebuild kit so I junked them and bought a new pair of Warn hubs. No more auto lock but now I no if they are in 4x4 or not. Good luck
Old Aug 30, 2005 | 09:46 AM
Hummer1823's Avatar
Hummer1823
I had the same problem with my drivers side hub... Stuck and would not turn...
So i took the wheel off and sprayed WD-40 in and around the hub area... NOW it turns just fine! The dealer told me that if you dont use your hubs alot they can get stuck like that.
Good luck to ya
Old Aug 30, 2005 | 11:09 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Good advice. A little WD goes a long way with manual hubs.
skyoung
Oct 5, 2011 10:33 AM
QH rancher
Offroad & 4x4
Nov 8, 2009 08:07 PM
arhuranna
May 21, 2009 02:44 PM
bud1963
Bronco II
Sep 7, 2005 09:04 PM
mstennes
Dec 15, 2004 11:05 PM
