lower radiator hose
Old Sep 3, 2002 | 08:47 PM
mick460's Avatar
mick460
lower radiator hose
I have a '79 F250 4x4 with a 460. I need to replace the lower radiator hose and went to my local Ford dealer with the old one in hand. The numbers were still readable and Mr PartsMan says it's a discontinued item. He says try parts stores. Well they can't find a listing for this motor/truck combonation and it must be a trial and fit thing. He couldn't even cross reference the Motorcraft number. What gives? Anybody else have this problem? Do you have a number that I can use for a Gates or other name brand hose? I tried looking thru the various suppliers and they don't handle radiator hoses.
Old Sep 3, 2002 | 09:01 PM
tellico racing's Avatar
tellico racing
lower radiator hose
I would tell the parts store your truck is a two wheel drive with a 460. Ford never put a 460 in a 4x4,It should fit.
78 F150 4x4
429 CID
Dana 44 spooled Front,
9"Locked rear,
5:13 Gears
17/40/15 Gumbo monster mudders
18/39.5/15 Swamper Boggers
BIG,BAD,and UGLY.
Old Sep 3, 2002 | 09:54 PM
Ford79's Avatar
Ford79
lower radiator hose
Yep, the 2wd hose fits in a 4x4. You may have to trim it a little, but it works fine.
Old Sep 4, 2002 | 07:21 PM
mick460's Avatar
mick460
lower radiator hose
Thanks. I did go to a different parts store after the post and they have one ordered for me. Apparently some parts stores try alittle harder than others.
Old Sep 4, 2002 | 09:10 PM
beartracks's Avatar
beartracks
lower radiator hose
...Now you know which one to go back to!
Old Sep 5, 2002 | 08:05 PM
mick460's Avatar
mick460
lower radiator hose
Seems ironic that the one that was in the truck had 3 or 4 bends in it and the replacement was just L shaped. It worked but it awful close to PS belt. Not touching but very near to touching. And yup I will be changing parts houses even thou I like going to the Ford dealer for most of my stuff. Gives me a chance to drool on the new stuff.
Old Sep 5, 2002 | 08:28 PM
trinogt's Avatar
trinogt
lower radiator hose
My 76 2wd 460 F150 has its lower hose close to the belt also. I replaced the rad, and when I put the hose back on, I rotated it enough to give about an inch of clearance.
Mark
Old Oct 28, 2003 | 08:26 AM
geraldww's Avatar
geraldww
Several parts stores have web sites. Some even display images of the parts. On hoses hey give the inlet/outlet/length size. Sometimes various brand/price options. One site that I've used even has a part number cross reference. Since I'm changing to a later model radiator and my inlet is being changed to the oposite side, I've searched for a later model hose. I have several candidates to choose from, just haven't been to the store to pick one up yet. Hope this helps
Old Oct 28, 2003 | 05:54 PM
classyfish's Avatar
classyfish
OOhh, sounds familiar. I just finished installing mine in my 79 crew 4x4 with 460. Anyway, I will go out to the garage and get the part number as soon my wife gets back to watch the wee ones.
Kevin
Old Oct 28, 2003 | 07:53 PM
classyfish's Avatar
classyfish
Here is the number. I believe the Gates 21048 is the right one. I took the tags off of 2 different hoses and forgot which is which.
The one that works perfectly has a slight curve back right after the water pump outlet. Thus missing the p.s. belt by a good 1/2 inch. Also, it misses the front crossmember. It actually just touched, but I trimmed about 1/4 inch off the end that goes into the water pump. I have no idea what this hose is actually for, but it works perfect. You will be able to tell right a way when you see it. Way better than the original. Dont get what the auto stores say, they dont work worth squat.
Kevin
Just found the receipt, it is the Gates 21048. Get it, you can't go wrong...
Old Oct 28, 2003 | 09:07 PM
Monster 78 F-150 4X4's Avatar
Thats what I did over the weekend with my 460 swap in to my f-150 4x4 I just went to the parts store and got one for a 2wd and trimmed it down mine was an L shape also but it works so that is all that I care. Mine is about 3/4" away from the PS belt.
Old Oct 28, 2003 | 09:41 PM
classyfish's Avatar
classyfish
F150 and F250 do have some differences. The 2wd one I got would hit the F250 crossmember and cause it to distort forcing it out a bit to just rub the belt. That is probably why it works good on the F150.
vettman
Oct 4, 2024 09:41 AM
cougar14
Mar 19, 2016 04:08 PM
02expy
May 14, 2014 02:55 PM
03trueblue
Aug 14, 2012 02:03 PM
Jimmygunz3
Dec 6, 2011 03:13 PM
