Newbie witha question
Old Aug 29, 2005 | 02:24 PM
whteglve's Avatar
whteglve
What years are the same body style as the 1963 Custom Cab Styleside? I need a new bed and I'm having trouble finding patches and/or a good bed for it.
Old Aug 29, 2005 | 02:31 PM
2bocat's Avatar
2bocat
1964-1966 are same beds. No patches available from aftermarket producers. Can maybe get your local sheetmetal shop to bend up some of the corner plates and other depending on skill level...
Old Aug 29, 2005 | 04:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 29, 2005 | 04:59 PM
61ford's Avatar
61ford
what about taking panels from a 67-72 longbed and cuttin them down to fit will that work? ive got to do the same to truck bed and i had thought about tryin that, anyone know anything about that
Old Aug 29, 2005 | 05:30 PM
mikecarson's Avatar
mikecarson
63 has the same bed as 57-60, I think.
Old Aug 29, 2005 | 09:14 PM
cdherman's Avatar
cdherman
mikecarson is correct. Your bed doesn't match the lines of the cab too well, right? Has a narrow tailgate? Sort of "refrigerator" style latches? (old style frig)
I think you can get a later 64-66 bed to bolt on there. That would be my suggestion. But perhaps you like the old look. Those older beds are hard to come by, as far as I know.
Old Aug 30, 2005 | 04:14 AM
camperspecial65's Avatar
camperspecial65
you are right mike...unless its a uni, then its strictly 61-3.....yours a long bed or shortbed...if its a uni...
cs65
Old Aug 30, 2005 | 07:03 AM
whteglve's Avatar
whteglve
its not a uni-body its just the styleside. You know with the simple round taillights.
Old Aug 30, 2005 | 07:06 AM
airharley's Avatar
airharley
You can also go the permenant route and install 1/8" flat steel or diamond plate. It will save a lot of aggrivations of trying to find something that might work. I have to do the same thing when I get home. My bed floor has a bunch of pin holes in it that need to be replaced. I am going to pull the bed off and carefully cut out the whole floor except for an inch strip along the edges. I want to have something to weld to. Not to mention the added weight will help a lot with traction issues or frame flex.
Old Aug 30, 2005 | 07:12 AM
FordBoypete's Avatar
FordBoypete
White Glove,
I 2nd Tim Larson with a Welcome to FTE & it's wealth of knowledge about Slicks. You will find an answer here for most Slick related questions, as well as some great alternatives for upgrades and retrofits to improve the breed. . . . if you're tolerant of hybridized Slicks.
I agree with cd, the easiest/ best way out of the problem is to find & use a 64-66 style side bed. Although it may not be what came on your 63 originally,as mike states, it will fit the body lines & windsplits of 61 through 66 F series trucks, except as cs65 noted the integral bed (aka uni body version which is a stand alone bed side panel in all cases).
Of course if you're doing a "Concours D'elegance" restoration for an AACA or Pebble Beach show than you're stuck with the bed Mike Carson mentioned. But for a sensible, easy qwik solution, go for a 64-66 Style side. 67 doesn't match the cab side profile or rear wheel opening either and really look weird (IMHO) altho' they will virtually bolt on.
FBp
Old Sep 2, 2005 | 07:31 AM
whteglve's Avatar
whteglve
Thanks for the help guys.
elbono
Jul 15, 2025 09:42 AM
SeaCarr
Apr 29, 2016 03:35 PM
woodsmoke
Jul 22, 2010 09:53 PM
mramoo
1983 - 2012 Ranger & B-Series
Jul 28, 2000 07:25 PM
chrisgordon13
Sep 12, 1999 12:05 AM
