rpm at 75?
Old Sep 3, 2002 | 01:27 AM
cjcathey2002's Avatar
cjcathey2002
rpm at 75?
ok i just got back to school and its about 400 miles. i drove a constant 80-85 mph the whole way, i got a c6 and 3.73 gears in the d60 rear. i only turn between 2500-2700 at 75 and 3000 at about a 1/4 inch past 85. this sounds a little low engine speed for the 3.73 rear, any ideas??
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
msd 6a and blaster coil
Old Sep 3, 2002 | 10:47 AM
andym's Avatar
andym
rpm at 75?
A C6 is going to slip about 10%, remember. It doesn't have a lockup converter.
Old Sep 3, 2002 | 11:14 AM
loudfords's Avatar
loudfords
rpm at 75?
What is your tire size? I'm turning more rpms than that with a 2.75 rear and 235/75/15 tires.
Old Sep 3, 2002 | 12:03 PM
fatdaddy's Avatar
fatdaddy
rpm at 75?
I think that either your tac is off and\or your speedo is wrong or maybe a combination of the two!!!!!!Especially , given the fact that you have a 10% slippage(assuming that number is accurate) which means that for purposes of explanation---say your rpm was 3000 at 70mph(not your actual numbers)--assuming a 1:1 ratio----with a 10% slippage your rpm would turnout to be---3,000\.9=3,333 if my division is accurate.........fd
Old Sep 3, 2002 | 12:21 PM
andym's Avatar
andym
rpm at 75?
[updated:LAST EDITED ON 03-Sep-02 AT 01:21 PM (EST)]You also can't accurately determine tire diameter by calculation using the tire size. To measure the size, do this:
Park the vehicle on a hard, level surface. Measure the distance between the ground and the center of the hub. This is the radius. Obviously, double it to get the diameter.
Now compare it to your calculated size, and you'll see what I mean.
Old Sep 3, 2002 | 01:28 PM
tetraruby's Avatar
tetraruby
rpm at 75?
Might be a little better to mark the sidewall of the tire and measure the distance (on the road) between each revolution- meaning the distance that corresponds to the mark after one revolution.
Old Sep 3, 2002 | 02:13 PM
fatdaddy's Avatar
fatdaddy
rpm at 75?
Touche!!!!!!!!!!!!fd
Old Sep 3, 2002 | 08:41 PM
cjcathey2002
rpm at 75?
my tires dont give a size as to how tall they are, all they say is 9.50x16.5LT they are pretty big, i would guess close to or more than 30 inches. the tach isnt off because at idle it reads 650. and the speedo isnt off, unless it is very very small because when i drive by those police things that tell you how fast you are going, it is spot on.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
Old Sep 3, 2002 | 11:04 PM
FE427TP's Avatar
FE427TP
rpm at 75?
there's something wrong with your spedometer if your getting 3000RPM at 75mph. 4.10's with my 235/75/15's are 3000@60mph. My 4.10's+.68 overdrive= 2100RPM give or take for 60 or 3000RPM for 90mph
Old Sep 3, 2002 | 11:44 PM
LxMan1's Avatar
LxMan1
rpm at 75?
Something is majorly wrong there. My 3.00 gear with 32" tall tires and a C6 only turns about 2350@75mph. I know mine is right! Cops told me so!!
Old Sep 3, 2002 | 11:49 PM
BB's Avatar
BB
rpm at 75?
>1977 F250 460
>C6 Hedman Headers
>Dual 40 series
>edelbrock performer
>holley 4160
Hey that's a pretty good guess! Most 9.50X16.5LT tires measure between 30.6 and 31 inches in diameter when new.
Something ain't right though...
Barry
Old Sep 6, 2002 | 12:03 AM
masterbeavis's Avatar
masterbeavis
rpm at 75?
[link:http://www.4lo.com/geartable.html|here is the answer, go here]
Tony
'77 F250, 4X4 460 transplantee, "Flamer"
'74 F250. 460, "beater" now "1 dead ford"
'73 F250, "midnight auto" now a trailer for the flamer
Old Sep 6, 2002 | 02:09 PM
strait6stick's Avatar
strait6stick
rpm at 75?
I had a 300-6 with the 3spd OD non grany manual trans.The rear was stock ratio?
would drive 65-70 with out the od.
Od at 50-55 truck almost stalled out
3rd went up to 90-100
4th the 300 would only push it 125-130
plenty of gear left.
The look on the import owner punks face when he hears me up shift at 95 <evil laugh>HA HA HA
Old Sep 7, 2002 | 05:32 AM
77Ford350's Avatar
77Ford350
rpm at 75?
Hello,
I own a '77 1 Ton, 460, C6, and 16.5x9.5 tires. I pull exactly 3500 rpm at 70 mph. 75 mph would be about 3600 I am sure. Just my 2 cents.
Old Sep 7, 2002 | 09:25 AM
Ford 76's Avatar
Ford 76
rpm at 75?
