Bronco II Ford Bronco II
Howling FM146
Old Aug 28, 2005 | 11:42 PM
admiralturbo's Avatar
admiralturbo
Exclamation Howling FM146
The Five speed in my 88 has been making a whining howling noise lately.It gets louderwhen you let off the gas and coast in gear.Noisy whrwaaaaaaa sound in neutral too,The oil level is proper.and besides being able to put it into two gears at once,runs fine. Any Bright ideas
Would the other style of five speed manual (the mazda or something) bolt right in?Or maybe an Exploder tranny?,since mine seems to be the only one in Canada with the FM146.
Old Aug 28, 2005 | 11:54 PM
87ford4x4inline6's Avatar
87ford4x4inline6
The Fm 146 and FM145 have a very week thrust bearing. The FM145 is 2" shorter then the FM146 and would require the tranny mount to be moved and your rear shaft lenghtened and front shortened. The TK5 is even shorter beening only a little over 25"s. I dont know the lenght of the M50D but it is a better transmission, it is found in 91 to 00 rangers and explorers with 4.0 engines. They will all bolt up to a 2.8, 2.9 and 4.0
Old Aug 30, 2005 | 06:52 PM
admiralturbo
Was it only the M5OD in the Explorers and newer Rangers?
Any one Out there know of the Exact interchangability of this Explorer tranny with my FM146?
Old Sep 5, 2005 | 10:43 PM
Jspafford's Avatar
Jspafford
I just put a M5OD out of a 1994 Ranger into my B2 in place of the Fm146. The only thing you need to change is the floor plate (4 bolts under carpet) and the shifter and both shifter boots for the tranny and tcase. Swap was simple. Can even reuse your slave cylinder. The tranny I put in was out of a 4.0 so the gearing is slightly different to match the 4.0's torque curve. Make the B2 scoot. Best thing I have done barnone
farmerchad
2004 - 2008 F150
Jan 22, 2017 03:57 PM
radck
Oct 30, 2016 04:01 PM
tinman565
Jul 24, 2015 05:21 PM
Shiny62
Bronco II
Oct 22, 2005 06:31 PM
xtmsports
Jun 27, 2005 10:28 PM
