02 F250 front end noise
Ok...you guys have ALWAYS come thru with the correct answer, so here goes (i apologize for the long post). 2002 Ford F250 4x4 Superduty Lariat (4 door). Just changed the locking hubs to a new set of Warn manuals. I began to periodically hear what sounds like a rumbling/bearingish/howling kinda sound. Happens when you hit a bump at any speed...then howls till you hit another bump..goes away..then process repeats. Come to a complete stop, and the sound usually goes away till you hit another bump. The hubs are "free" at this time. Heres the weird thing...when the noise starts...I switch it into 4 wheel drive on the dash...the sound instantly goes away. Click it back outta 4 wheel drive (hubs are still unlocked this whole time) and the sound is gone. drive some more down the road, maybe hit a slight bump, and the sound returns. Switch it back into 4x4...sound instantly goes away. Its not really in 4 wheel drive, cause the hubs arent locked in...but that cures it till I take it back out. Any ideas as to what could be causing this howling ? Its getting worse, and you can feel a slight vibration in the floor now when its doing it. Thanks guys.
Yup needle bearings. Just went threw it on mine. I replaced the hub bearing assy because it was under warrenty but it galled up the stub shaft so that got replaced and a new u-joint and both seals. The torrington needle bearings are only about 13 bucks here and easy to change but my assembly was under warrenty so I just got a new one. I would suggest locking in the hubs till you get it done or your stub shaft will probably be galled.
part number
Well...took it apart this morning....and it was the needle bearing at the end of the shaft. It didnt tear up the shaft (whew), and as soon as I had the hub off...4 of the needle bearings fell out...lol. I went to NAPA, and $11 later, had it repaired. Thanks for the help guys !!!!!
SuperDutyScaler
1999 to 2016 Super Duty
46
09-09-2015 05:08 PM
Lloydable
13
08-03-2015 11:09 AM
ANigrelli132
06-24-2014 10:38 AM
