Overcharging...not alternator?
Old Aug 28, 2005 | 10:24 PM
willy2005's Avatar
willy2005
Question Overcharging...not alternator?
On my drive home from work yesterday I noticed my battery light on & the voltage gage pegged high. Came to a stop light, voltage returned to normal, light went out. At first acceleration, light on & high voltage. I turned on everything I could (headlights, AC, etc) & this held voltage normal until I got to the Sears garage who tested the battery. Battery good & something is overcharging....probably alternator but he couldnt test it. I made it home & decided to remove the alternator & take it in for a bench test. Tested good at both Autozone & Pep Boys. Got home, cleaned & tightened all connections & problem did not reappear until this afternoon. Same thing.
I've never seen a high voltage fault before. I'm also confused with the intermintent times it happens. Only when I get RPM's near 2000 & there is no load elsewhere. This is a stock XL with no electrical options.
Any and all advice is appreciated.
if it helps:
2003 Ford F-150 XL
4.2 6-cyl, manual transmission
48000 miles
-Bill
Old Aug 28, 2005 | 10:35 PM
Franklin2's Avatar
Franklin2
I don't know how much they are, but you may want to try an alternator anyway. If we assume all the connections are good, and I think you have an internally regulated alternator, it may be a heat related fault that will not show up after it cools off and you take it to the store.
Just to be sure, have someone watch the guage while you go out and wiggle the wiring and the connections(don't get caught in the belt!) to see if you can make it fail.
Old Aug 29, 2005 | 09:25 PM
thefonz#1's Avatar
thefonz#1
overcharging
Mine did this and I went bonkers trying to figure it out. Everything I found was problems with undercharging. Any how, try running a seperate ground from alt. to frame or metal body part, takes maybe 10 minutes tops and worth a try. It fixed my problem.
[I probably wouldn't have listened to this suggestion cause I know it is supposed to get it's ground by being bolted up, but I was at my wits end... It's worth a shot]
hukdonquack
243
Jul 16, 2008 06:40 AM
fordgta
Electrical Systems/Wiring
Jan 17, 2005 06:12 PM
REDJAR
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 16, 2004 12:13 PM
black460
16
Dec 6, 2004 05:50 PM
mayhem
Aug 30, 2004 01:25 PM
