Tranny Question
Old Aug 28, 2005 | 05:49 PM
boogity24's Avatar
boogity24
Question Tranny Question
Would a 4-speed with a granny out of a 1985 f150 300i6 bolt on to my 302??
With no problems??
Old Aug 28, 2005 | 06:24 PM
The_Ryan_Lilly's Avatar
The_Ryan_Lilly
the engine and transmission wil bolt up fine, buy may have to move the crossmember and lengthen/shorten the driveshaft, depending on that you currently have in there.
Old Aug 28, 2005 | 07:56 PM
boogity24's Avatar
boogity24
i have a 3 speed in there now, my buddy just wrecked his truck and is parting it out, and I was just wondering if that tranny would be worth trading it out for mine?
Old Aug 29, 2005 | 10:06 AM
Mike G's Avatar
Mike G
Depends on what you want in the end... One thing to consider is that I believe the final gear ratio is still going to be 1:1, so you are not picking up a final gear reduction or OD situation.
Just a thought, --Mike
Old Aug 29, 2005 | 01:07 PM
fordguy76's Avatar
fordguy76
I know that this is your question, but don't some of those '80's 4spd shifters crook differently than the old ones? Would this hit the dash? I guess they could be swapped if they're both the same type 4spd.
Old Aug 30, 2005 | 07:39 AM
69 and 85's Avatar
69 and 85
Might want to take a look at the driveshafts too... some trannys are splined on the output and need a yoke and single driveshaft - other trannys have outputs that are "a yoke" and have a 2 piece driveshaft that is splined- main point being you need a splined connection somewhere to absorb the changing length that occurs when the ol rearend goes bouncing from potholes, etc.
Old Aug 30, 2005 | 02:55 PM
WillyB's Avatar
WillyB
Don't give the floor shifter a second thought - they bend as needed. Just heat it with a torch, and bend away. It is not hard to change where the shifter ends up when in the different gears. You want it where first and third do not hit the dash, and second and forth do not hit the seat.
Old Aug 31, 2005 | 07:49 AM
jowilker's Avatar
jowilker
boogity, Unless you have some big need to tow or pull, you will gain nothing. Most use second gear to start and with a final ratio 1 to 1, you still have a 3 spd.
John
Old Sep 1, 2005 | 01:53 PM
boogity24's Avatar
boogity24
so all i would have to do is swap out the trannys?? i like the thought of having the granny, and it has a brand new clutch. im tired of fiddiling with my shifter that seems like no matter what its going to be backwards. and ill have to change my clutch soon anyways.
Old Sep 1, 2005 | 07:57 PM
WillyB's Avatar
WillyB
Yes, it is likely to be that easy, but as others have said you need to look and make sure what you are getting into with the crossmembers and driveshaft. If you will post the year and model of your truck and the year model of the donor truck maybe someone can give a better answer.
Also, on some trucks (67 and up, to my knowledge) the transmission hump is different - you would need to bolt a 4 speed hump in as it is a few inches deeper (taller?). In any case you will need to cut a hole in your floor and mount a rubber boot around the bottom of the shifter.
It is a change I would make in a heartbeat -
Old Sep 2, 2005 | 01:01 PM
boogity24's Avatar
boogity24
I have a 1972 f100 swb with a 302 3spd, that im pretty sure came out of a 69 mustang, and he has a 1985 f150 swb with a 300 4spd
