1978 - 1996 Big Bronco
Timing Mark
Old Aug 28, 2005 | 03:20 PM
madmader's Avatar
madmader
Timing Mark
Which is the timing mark on the above picture? I have always timed this truck by ear, and I am having troubles with it, and need to do an "acturate" timing check on it...
Old Aug 29, 2005 | 07:21 AM
Streetgang's Avatar
Streetgang
First I would get the flywheel all cleaned up nice, so you can read all the markings on it. It should show TDC and grads of 5*. You would use the pointer on the block to reference the degree markings on the flywheel. The stock base timing with the SPOUT out is 10* BTDC.
The truck should be warmed up first......then remove the SPOUT plug/connector. Loosen the dizzy retainer bolt. Connect the timing light to cyl#1, and set to 10*BTDC . re-tighten the dizzy, and recheck the timing.
Some guys here who have done a bit of engine mods set the timing to 13* or even 14* BTDC
Old Aug 29, 2005 | 06:13 PM
Jdenninger's Avatar
Jdenninger
madmader, check this site, it will tell you all the info you need for your 79:
http://home.earthlink.net/~bubbaf250/index.html
Outlaw56
22
Apr 6, 2014 05:59 PM
maverick600
Sep 16, 2013 06:28 PM
84respass
Oct 5, 2010 10:09 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Aug 11, 2009 09:07 AM
taylen
Aug 25, 2005 06:56 PM
