MAF Sensor Problem
Old Aug 27, 2005 | 04:00 PM
Mountaineer Boy's Avatar
Mountaineer Boy
Unhappy MAF Sensor Problem
Well my engine was acting up in my 98 Mountaineer and from the forum posts it seemed like the MAF sensor (and this was what the check engine light indicated) was the problem. Well I bought a new one, put it in, and everything works fine, for a while, then the problem returns, engine bucking like it isn't getting any spark or fuel. The check engine stayed off for a bit but is now back on with the same code, I think it's 0401.....any suggestions.
Old Aug 27, 2005 | 06:46 PM
vicv's Avatar
vicv
I found all these P04XX codes, all refer to the EGR system. Could be a bad valve, sensor, or leak in the lines. I'd check all the basic stuff 1st, plugs wires, filters, etc if you haven't already done so. I went nuts for several weeks looking for the cause of a miss only to find a new plug was bad. Good luck...
P0400
Exhaust Gas Recirculation Flow Malfunction
P0401
Exhaust Gas Recirculation Flow Insufficient Detected
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Circuit Malfunction
P0404
Exhaust Gas Recirculation Circuit Range/Performance
P0405
Exhaust Gas Recirculation Sensor A Circuit Low
P0406
Exhaust Gas Recirculation Sensor A Circuit High
P0407
Exhaust Gas Recirculation Sensor B Circuit Low
P0408
Exhaust Gas Recirculation Sensor B Circuit High
http://www.troublecodes.net/OBD2
Old Aug 27, 2005 | 08:28 PM
bulldog3531's Avatar
bulldog3531
could be your DPFE sensor. I had a code 0402. changed the sensor and no more CEL.
Old Aug 27, 2005 | 11:13 PM
Jharger's Avatar
Jharger
Though I am usually caustious optimistic on Vic's advice - I would agree with him here and Bulldog. DPFE sensros are notorious on the late model X's. Notorious - like Jessie James or Billy the kid.
94BigRed
Oct 11, 2013 01:29 AM
dlmoye
1983 - 2012 Ranger & B-Series
Jun 9, 2012 04:36 PM
khadma
1997 - 2003 F150
Sep 24, 2011 11:01 PM
Ole'Blu
Jul 5, 2011 09:33 PM
jvaski
1997 - 2003 F150
Dec 26, 2004 06:01 PM
