Flathead Oil Pump
Old Aug 25, 2005 | 10:47 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
Flathead Oil Pump
My oil pressure is fine I was wondering if anyone has done any machining to the pumps to close up the tolerances to increase flow and pressure? In the past on a old VW Bug I had parts such as the pump body machined for minimum clearance between the end plate and the the gears. Then had the gears coated and built up to reduce the clearance between gears to minimum. That increased my oil pressure almost two fold on a new oil pump.
Argess
Jul 26, 2011 08:17 AM
IowaTower
Jan 19, 2006 10:44 PM
Third Coast
Aug 29, 2005 07:54 PM
86rustbucket
16
Jul 19, 2005 11:30 AM
faskar
1978 - 1996 Big Bronco
Apr 23, 2001 12:10 PM
