De-Tune for longer life?
Is it possible to de tune the 6.0 engine for longer life? The International 6.0 has 230 hp & 620 lbs torque and no problems. Isn't it the boosted hp that is causing the reliability issues with the Ford engine?
Hmmm...dejavu...Where have I seen this before?
IMO, detuning has the potential to create more issues. Detuning might cause the engine unwarranted stress due to the fact that it is not able to perform as originally designed. Under tow / haul conditions this may in fact load up the system. Kind of a programming castration so to speak.
The opposite effect of to much programming.
I would be interested to hear how the engine performs with a MAX RPM of 2600. I suspect it would be just fine as I rarely go above that RPM myself.
RoyC
Even towing across the passes. Manually selecting gears.. I've seldom gone past 3000rpm. And never hit 4000. I pretty much limit my driving to be well below 2800, most often I shift below 2000. And since 2000rpm in fifth gear is just near 70mph, there's not much more I need. So... Driving like a concious adult, I guess just doing that I've been running the engine "detuned". If that's it, all there is is a rev limiter difference between the 365 and the 6.0.
-Steve
-Steve
Originally Posted by jackofalltrades
Driving like a concious adult-Steve
Just kidding, I know what you mean...although it implies that if people don't drive like you they not conscientious.
Maybe in 07 they can have that gee wow super power 6.4 twin turbo headache waiting to happen and the nice as designed International 6.0 as they offer in the F650 trucks ...trucks that are built for far more weight load than the 250 - 550 series ...
I expect to see 2 diesel options available for the F-250, 360's at some time in the near future. I would like to see a smaller displacement motor with better mpg and maybe a 6 speed auto or 7 speed manual with better splits. (I think the twin turbos are to get rid of the EGR, I hope, I hope, I hope.) I do pull a 5-w but I don't mind shifting down a gear or so to get up a mtn.
Originally Posted by kw5413
It seems the thing to do these days.
not another engine that seems as though the majority of Fords own dealer techs have no clue .... I feel lucky in that I found an awesome dealer that really knows diesels ... been to quite a few across the US that are clueless ...
my truck has 125,000 miles on a new engine ...engine one was toast around 3,000 ....
