1978 - 1996 Big Bronco
B-Pillar on Bronco
Old Aug 23, 2005 | 09:07 PM
BootHill's Avatar
BootHill
B-Pillar on Bronco
I am looking at mounting some speakers in the B-pillar on my Bronco. Is there anything inside the pillar behind where the seatbelt strap is located that I might cut into by accident?
Old Aug 24, 2005 | 07:55 AM
scurbiedog's Avatar
scurbiedog
No I don't believe so but dont you have the openings for speakers there or are just trying to open the hole up a little to put in larger speakers?
Old Aug 24, 2005 | 09:44 AM
BootHill's Avatar
BootHill
There is currently no opening on my B-pillar for speakers. There is one in the door and one next to the rear seat behind the B-pillar. I wanted to mount some up on the B-pillar between the windows so I could hear it without blasting the radio when the windows are open, because the loud tires drown out the radio and sound deadening in my Bronco is not so great.
Old Aug 24, 2005 | 10:24 PM
Tazz452's Avatar
Tazz452
a couple of things to think about.... depending on how high you mount the speaker you may not have enough depth (to the outside skin) for the magnet. Also just as a safety note dont cut to close to the top seat belt mount because you will weaken that point. Hate to see you pull the top belt stud out of the b pillar in an accident.
Old Aug 25, 2005 | 06:33 AM
jesta302's Avatar
jesta302
Why not try some really good replacement speakers with plenty of power? My '95 Bronco has a killer system with Polk's in the factory rear. The mounts tilt nicely forward, engineered sort of thing... The key is good clean power. Good power will overcome outside noises. (And I am not talking about rap cannons either..)
Of course, this IMO.
Old Aug 25, 2005 | 10:18 AM
BootHill's Avatar
BootHill
jesta302,
I agree that a good sound system overcomes most of the outside noise problems, except for one problem in my case: cost. I have some speakers already and am broke. So decision is to hear the music (or talk radio) or not hear it.
Thanks
Old Aug 25, 2005 | 04:16 PM
jesta302's Avatar
jesta302
10-4, then OK back to my hillbilly roots....
Just brainstorming here, but I've done a LOT of stereo set-ups. JB WELD that rascal to your post. You decide the bracket set-up/box based on what your shop has laying around, then rock & roll. I agree to not drill it at all. JB WELD is one of those products that actually does what it says. You can do a neat job, then sand off to desired look, and paint it to match. Just tossing around some ideas. You could even build a "base" to work off of, then mount to that.
blwn88cpe
2009 - 2014 F150
Feb 6, 2017 01:41 PM
mattnj
Oct 1, 2016 07:01 AM
sloate9471
Aug 30, 2016 01:18 AM
troy676
Apr 23, 2015 04:50 PM
tabijan
18
May 26, 2014 05:52 PM
