diff poping when turning left???
Old Aug 23, 2005 | 02:32 PM
OSin86's Avatar
OSin86
Today I was hualing a mini track hoe with my 86 F-350 dually, like I normaly do from time to time, and encountered a horrible poping noise when turning left. Turning right, under load or not is fine. Turning left under load is the only way it happens. I can coast left not under load and be fine. I dropped the trailer and it still does it.
under load = using the gas
not under load = coasting
Any ideas what this could be? Anybody else have this problem.
Thanks
Old Aug 23, 2005 | 03:11 PM
andym's Avatar
andym
Is this 4x4? Can you isolate the noise a little more by having someone listen from the outside while you drive it?
Old Aug 23, 2005 | 04:18 PM
fordboy_52's Avatar
fordboy_52
could be a bad bearing as the bearing and the retainer hold the axle in when turning
Matt
Old Aug 23, 2005 | 04:44 PM
OSin86's Avatar
OSin86
2 wheel drive, and deffiantly in the rear. I'll jack it up in the morning and see if anything is obvious. Thanks for the help.
Old Aug 23, 2005 | 05:42 PM
OSin86's Avatar
OSin86
Okay, didn't wait untill morning. I jacked it up and pulled the axles. Both outer bearings look great. I took the diff cover off and no obvious shavings or anything in the oil. I'm not too sure what I should be looking at in there to be honest. I'm tempted to take the diff out but then what?
Just a recap, it only "pops" when turning left and you have it under load. Any amount of throttle will make it pop and if I push in the clutch it won't do it. Does not do it when turning right.
Thanks
Old Aug 23, 2005 | 06:32 PM
OSin86's Avatar
OSin86
UPDATE:
I took the differential out and all the bearings and gears look great but the steel and friction plates are TOAST! There's grove marks in them.
Old Aug 24, 2005 | 10:48 AM
OSin86's Avatar
OSin86
It was the limited slip clutch pack.
Old Aug 30, 2005 | 12:47 AM
rfxj3's Avatar
rfxj3
Thanks for following up and posting the updates - really helps out those who are reading this later that may have a similar problem.
Razor
