Sponsored by: Real Truck
Adjustable track bar for 2.5" level?
Old Aug 25, 2005 | 10:06 AM
Robert6401's Avatar
Robert6401
If I go with the DR Mini Spring Pack instead of the hangers, would it still be beneficial for me to get the adjustable track bar or relocation bracket? Also, with either the hangers or the spring pack do I need new shocks? Thanks
Old Aug 25, 2005 | 09:38 PM
BFR250SD's Avatar
BFR250SD
Do yourself a favor and get the new shocks. Most of them say taht you don't need them until you go 3" or more, but you're right at that limit. Plus, you'll be much happier with some good shocks vs the stockers. Get some adjustables, Rancho RS9000X's or Pro-Comp MX6's. I put the Rancho's on mine and it was night and day.
Old Aug 26, 2005 | 03:46 AM
Robert6401's Avatar
Robert6401
OK, for the sake of saving money, it looks like I could go without them in the beginning though, until I can convince my accountant (wife) that I need new shocks too, right? Also, is there anything wrong with replacing the front shocks only, once again to appease the accountant (wife)? Thanks.
Old Aug 26, 2005 | 04:08 AM
BFR250SD's Avatar
BFR250SD
If you're not changing anything out back, you're fine.
Old Aug 26, 2005 | 06:46 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yeah i wished i would have had the adjustable track bar when i put on my leveling kit (2''). even the little amount of lift, it still pulled the axle to the left about 2''
Old Aug 26, 2005 | 07:45 AM
Robert6401's Avatar
Robert6401
Was planning on adding 4" blocks to the rear, so I guess I'll need to change out those shocks too. Thanks.
Old Aug 26, 2005 | 08:16 AM
BFR250SD's Avatar
BFR250SD
You should already have 2" blocks, so it's only a 2" increase. You should be okay.
Old Aug 26, 2005 | 08:26 AM
blankman's Avatar
blankman
Thumbs up
I don't know a thing about lifting a truck, but BTR250SD that is one awesome looking truck!!
Old Aug 26, 2005 | 08:27 AM
BFR250SD's Avatar
BFR250SD
Thanks man. I appreciate it.
Old Aug 26, 2005 | 05:55 PM
Antelope V-10's Avatar
Antelope V-10
My factory trac bar measures 29.5 C-T-C and the Fabtech Bar with Rancho 2.5 springs measures 30.250 C-T-C. As illustrated above, {nice job by the way}, you can see how much easier it is by having an adjustable trac bar.
As far as shocks go, if your putting a 4" F-350 block, just ask for shocks for a stock F-350. If I remember right, they should be the same as a stock f-250 anyway.
Old Aug 26, 2005 | 07:42 PM
BigRyanKP's Avatar
BigRyanKP
When I did my edge 3” shackle lift, I took the track bar off and measured how much it needed to be lengthened, cut the trac-bar in half took some 1" solid bar ground the edges down a little to get better welds and welded a piece in there to lengthen it. Before I welded it though I slid a piece of black iron pipe over the bar so that when I was done welding the bar the pipe would slide over the welds and then I could weld the ends of the pipe too. It looks very nice and worked very well its right on when I slid it up in there. Saved myself $250 or whatever the ridiculous price of an adjustable trac-bar is.
Old Aug 27, 2005 | 03:54 AM
Robert6401's Avatar
Robert6401
I just bought the Fabtech adjustable track bar for $98.50 from Summitracing.com, thanks for all the help everyone. I havent decided on which leveling kit to go with, and since I am still in Iraq for a couple more months I dont have to make the decision right away. Im just glad I ran across the track bar while it was on clearance.
Hockycop
Jun 11, 2024 09:48 AM
pin8246
Aug 10, 2012 07:55 PM
Gwilkrrs
6.4L Power Stroke Diesel
Jun 23, 2011 12:39 PM
Boss_hoss
Apr 4, 2011 04:03 PM
