Starting problem
Old Sep 16, 2002 | 07:32 AM
71swissaqua's Avatar
71swissaqua
Starting problem
Old Sep 18, 2002 | 07:30 AM
D2D4's Avatar
D2D4
Post Starting problem
I'm a new member and find this a great site! My 76 F150 has a problem that has me stumpped. When the key is turned to "start" the engine turns over very strong and will continue to do so but will not fire till I relaese the key then it will start. I checked for fire at the plugs and have none while cranking but the second you release the key it will fire and start. I have a new Ign. box,cap and rotor. Could it be in the ign. switch? Again great site thanks, Cliff.
Old Sep 18, 2002 | 07:38 AM
jalampi's Avatar
jalampi
Starting problem
Ck your wireing under the hood for rubbed through or broken wires.
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old Sep 18, 2002 | 12:40 PM
Mil1ion's Avatar
Mil1ion
Starting problem
Sounds like an ignition switch to me.
With the key in the RUN position go to the battery + post and use a wire to contact the S terminal of the solenoid to see if the starter turns over and the engine starts up.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 18, 2002 | 12:50 PM
76supercab's Avatar
76supercab
Starting problem
(Horshack's arm shoots up) Ooo! OOOOoooooo! Ooo! Ooo! OOOOooooOOoOoOo! I KNOW this one. Gold plated guarantee. The ignition box. Mounted to the driver's side inner fender. Has 2 circuits in it. The start circuit has died. The run circuit is still good. Had this exact same thing happen on my dad's 76. Napa has the box for around $30. 3 screws and 2 plugs. 15 minute job and your golden again.
Write it down, take it to the bank and tell 'em I told you so!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
