Twin-I-Beam
Old Sep 16, 2002 | 01:46 AM
Polkat's Avatar
Polkat
Twin-I-Beam
I want to do some alignment on my '73. I haven't worked with the twin I beams before, and it looks as if the only adjustment is toe!! I must be wrong about this, so can somebody fill me in?? Thanks, Polkat
Old Sep 16, 2002 | 07:32 AM
71swissaqua's Avatar
71swissaqua
Twin-I-Beam
Hey Polkat, you'll have to take it to an alignment shop that has the ability to bend the I-beams to set the caster. Probably a truck shop. I hav'nt had to have my caster set in over 20 years though. Ford Tough.
Clint
Old Sep 16, 2002 | 07:42 AM
laptopgeek's Avatar
laptopgeek
Twin-I-Beam
71swissaqua --
Polkat is right; all you have to "adjust" is toe. The caster / camber is done by bending the I-beams if really needed; here in Metro Atlanta there are only a few people left who do this kind of thing.
Good Luck...
Old Sep 16, 2002 | 08:34 AM
73Custom's Avatar
73Custom
Twin-I-Beam
About 6 years ago my '73 was wearing the inside of the tires and the tires appeared to be tipped in at the tops. I assumed it needed an alignment - turned out it was weak coil springs. The twin Ibeam design must have the correct spring height, or the alignment is off. Once I replaced my weak springs with stock replacements, everything was correct. Might be what's going on with yours too...
Marty
Old Sep 16, 2002 | 09:55 AM
beartracks's Avatar
beartracks
Twin-I-Beam
Just for clarification: The toe is adjusted in the normal manner by turning a sleave on the tie rod. Camber is adjusted by bending the "I" beam and castor is not "normally" adjustable.
Old Sep 16, 2002 | 10:09 AM
laptopgeek's Avatar
laptopgeek
Twin-I-Beam
Just for clarification, castor is oil from the castor bean - used to make castor oil. The term "caster" is used for automotive vehicles.
Old Sep 16, 2002 | 10:20 PM
Thudpucker's Avatar
Thudpucker
Twin-I-Beam
Ah yessss... the odor of Castor the Bean oil is what made them Motorcycle races smell so exciting.
I had to have my 73 aligned in 75?? but the alignment didn't stop the pulling. It was a bad spring. I replaced both, did the rear wheel bearing adjustments again and had a brand new truck once more.
Old Sep 16, 2002 | 11:04 PM
Mil1ion's Avatar
Mil1ion
Twin-I-Beam
Up here in Alberta,we have a town called :
*Caster*.
In this town you can Cast'ur eyes on the new Castor oil while figuring the Caster on your Ford truck while Bending & Sitting on a chair with Casters,Casting yet another possiblity of a Caster Rating.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Sep 17, 2002 | 06:29 PM
FE427TP's Avatar
FE427TP
Twin-I-Beam
[updated:LAST EDITED ON 17-Sep-02 AT 07:31 PM (EST)]>Up here in Alberta,we have a town called :
>*Caster*.
>[font color=red]Dennis [/font color=red]
You are a sick sick person
Old Sep 17, 2002 | 07:30 PM
Polkat's Avatar
Polkat
Twin-I-Beam
Now, let me see if I have this straight. If I wanna align my truck, I have to drink castor oil while sitting on a chair with casters, perhaps on my boat while cast'ing for camberhead bass with a chair and... hummm...that old Mopar is starting to look good again! Polkat
Old Sep 18, 2002 | 11:23 AM
beartracks's Avatar
beartracks
Twin-I-Beam
I think someone has castasspersions upon me!
Old Sep 18, 2002 | 01:04 PM
laptopgeek's Avatar
laptopgeek
Twin-I-Beam
Kasterlahveesta, baby....!
Old Sep 18, 2002 | 02:05 PM
Graffe's Avatar
Graffe
Twin-I-Beam
Polkat
Nov 27, 2002 10:42 PM
Polkat
Oct 30, 2002 01:14 AM
Polkat
Oct 5, 2002 09:54 PM
oleblue70
Apr 25, 2002 01:59 PM
