CAN bus
Old Aug 21, 2005 | 01:22 PM
cankiss's Avatar
cankiss
CAN bus
Dose anybody know what kind of CAN protocol is used in the 2004 F150?
Old Aug 22, 2005 | 06:14 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 22, 2005 | 10:57 AM
GordoPanocho's Avatar
GordoPanocho
I don't know how much he's posting in this forum lately, but the guy with the most info on this subject is Rambunctious. Rob's a "Chief Engineer, New Product Strategy and Business Development" for the overhead systems at Johnson Controls Interiors (who make these things for Ford).
Old Aug 22, 2005 | 11:32 AM
4.6Ranger's Avatar
4.6Ranger
can bus
I'm not sure exactlly what info you want but here is the info i have
The CAN has an unshielded twisted pair cable, data bus plus, circuit 1827 (WH/L) and data bus minus, circuit 1828 (PK/LG).
The CAN permits inter-module communication between the DLC, PCM, instrument cluster and the ABS module. When the diagnostic tool communicates to modules on the CAN, the diagnostic tool must request all information or initiate module commands Hope this helps.
Old Aug 22, 2005 | 01:04 PM
cankiss's Avatar
cankiss
In older vehicles the communication protocol based on J1850 standart was used.
Do you know if the CAN is a J1979 or J1939 protocol (os is this only a typo?)?
Old Aug 22, 2005 | 04:24 PM
4.6Ranger's Avatar
4.6Ranger
can bus
Found it
High speed controller area network is based on SAE J2284, ISO 11898
I think that is what you were looking for.
Old Aug 22, 2005 | 09:29 PM
redcloud's Avatar
redcloud
CAN bus in 2005 Ford F150
Cankiss
In case you don't have access to the SAE and ISO documents, it's 500k bit/sec data rate, 11 bit address.
Old Aug 23, 2005 | 05:54 AM
IB Tim's Avatar
IB Tim
Welcome to FTE redcloud.
Old Aug 23, 2005 | 06:04 PM
cankiss's Avatar
cankiss
Thank you all. This was a great help.
mrwrench
Oct 17, 2022 06:07 AM
abe
38
Apr 24, 2016 08:40 PM
Mar 9, 2016 12:40 PM
David Fulmer
Nov 8, 2015 03:13 PM
spdmpo
Feb 19, 2010 07:28 PM
