Front end Question
Old Aug 21, 2005 | 12:11 PM
SilverBullet131313's Avatar
SilverBullet131313
Front end Question
Was under my truck the other day installing exhaust....and was just looking/poking around.....i noticed if i spin the front driveshaft.....it turns freely either direction and it spins the coupling(not sure what it is called) on the inside drivers side wheel. Nothing else just that. This normal????? Doesnt seem like it but figured i would ask.
Thanks Guys.
Old Aug 21, 2005 | 12:17 PM
WA.Ranger's Avatar
WA.Ranger
The front drive shaft spinning freely is normal.
Old Aug 21, 2005 | 12:36 PM
Kwikkordead's Avatar
Kwikkordead
Thanks Guys.
Thier open diffs on the front so the torque is transferred to the shaft of LEAST resistance. The left shaft being shorter than the right I would surmise that it's going to be the one rotating. I doubt there is a problem but you might try spinning the right side universal next to the ball joints to see if it turns freely. (Freely being a relative term, you have to move some pretty big gears) The resistance to turn should be sort of the same on left and right if you try rotating the axles at the u-joints. Make sure the hubs are unlocked, of course.
chad_mcvay
2004 - 2008 F150
Oct 15, 2012 03:08 PM
Ds7776
Dec 24, 2010 08:20 PM
arkredneck
33
Nov 11, 2007 08:36 AM
fordxl68
Offroad & 4x4
Oct 21, 2005 05:36 PM
dangaus
31
Aug 15, 2005 04:02 PM
