Source for throttle bore bushings
Old Aug 21, 2005 | 01:44 AM
rfxj3's Avatar
rfxj3
I tried searching the forum for this info but the search function is/was disabled so I am posting a new topic.
Where can one buy/order throttle bore bushings for the Motorcraft/Autolite 2100/2150 series of 2V carburetors? I have checked vendors such as Jeffs and RockAuto as well as Advance Auto with no luck. I am no machinist by any means but figure I can drill out a new hole to tap in a bushing if it will help seal the leaks around the throttle shaft. I just need to find some bushings.
Thanks for any help.
Old Aug 21, 2005 | 06:05 PM
Ford_Six's Avatar
Ford_Six
I don't know of any companies that make bushings specifically for these. One of these days, I am going to get around to making brass sleeve bushings for one of my carbs. I figure if I measure the shaft, find a piece of brass tube with the same size ID or a little smaller, drill the carb out for the OD of the brass tube, and maybe epoxy them in place or just let them ride in the bores.
Old Aug 22, 2005 | 04:19 AM
rfxj3's Avatar
rfxj3
Thanks Jared, I was thinking of doing the same if I couldn't find some already packaged up for this carb. Now I will have to find someplace that will carry brass tubing with the proper ID as I do not have a milling machine. Any suggestions?
Old Aug 22, 2005 | 01:42 PM
Ford_Six's Avatar
Ford_Six
Measure the bearing area of the throttle shaft with calipers or a micrometer, and then go to your local hobby shop. Most stock K&S brass tubing and shapes.
Old Aug 22, 2005 | 05:45 PM
LxMan1's Avatar
LxMan1
Have you contacted Pony Carbs yet? They rebuild a lot of Ford carbs and may be able to sell you what you need.
pnp522
Mar 8, 2013 09:15 AM
cordespc
Oct 7, 2007 08:24 AM
mattselland
Sep 30, 2006 01:15 AM
BuddyFord
Sep 26, 2006 07:21 PM
airharley
Aug 31, 2006 10:46 PM
