Ford 8.8?
Old Aug 20, 2005 | 09:27 PM
Wiskey6's Avatar
Wiskey6
Ford 8.8?
I know the van older rear ends used to be narrower than the truck rearends, but...What about now a days.
Does any one know if there is a difference between an E150,8.8 and an 8.8 out of an F150 before they switched to disk brakes???
I want to go to 4.10s, LS, and a used rear end may be loads cheaper than getting gears and an LS set up.
Old Aug 21, 2005 | 01:29 PM
kennethl6's Avatar
kennethl6
The vans from the late 70's on, are normally wider than the F series trucks.
Old Aug 21, 2005 | 05:43 PM
Wiskey6's Avatar
Wiskey6
Your right.
I had it bass aackwards! I found a site with the measurments.
This is going to be a real pain.
Old Aug 21, 2005 | 05:57 PM
chrono4's Avatar
chrono4
am i seeing double? lol, what tires you runnin that you need a 4.10?
Old Aug 21, 2005 | 09:51 PM
Wiskey6's Avatar
Wiskey6
Right now it has 235/75-15s on it.
It's a conversion with a 4.6.
I plan on doing a little towing, but aprt from that, it is just alot of van to get and keep moving and real hard on it in the hills.
I also want to put an LS on it.
Took forever to get either of those previous post to post...Oh well.
Old Aug 22, 2005 | 08:51 PM
chrono4's Avatar
chrono4
well,i you want, i can measure my axle on my 88, its a8.8, just let me know.
Old Aug 22, 2005 | 11:19 PM
Wiskey6's Avatar
Wiskey6
Thanks chrono, but I am pretty sure at this point that it is narrower.
BURNSTOUGHFORD
1997 - 2003 F150
17
Jun 2, 2008 12:41 PM
Hillbilly_Deluxe
1997 - 2003 F150
May 14, 2008 10:01 PM
nighthawk285
31
Mar 30, 2007 03:43 PM
alwaysmessedup
Jun 23, 2003 11:36 PM
andym
Aug 20, 2002 12:31 PM
