Inter cooler tube
Old Aug 18, 2005 | 10:06 PM
EPDP99's Avatar
EPDP99
Inter cooler tube
On my 05 f-350 i have the dual alternator set-up and looking at the passenger side tube it looks quite restrictive. does anybody make one that doesnt do that or is there a possibility of just removing the second alternator since i dont have a high load on my truck or would the single put out less amperage? Any options Id appreciate it.
Old Aug 22, 2005 | 04:47 PM
EPDP99's Avatar
EPDP99
nobody has any ideas!!
Old Aug 22, 2005 | 04:51 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Hmm... I have a feeling it is quite literally 2 alternators, each of the same capacity as the single small duty alternator.
The main problem would be the FEAD (Front End Accesory Drive) belt being too long. If you got one of those off a truck that only had a single alternator that should fix that.
Personally I like having 2 alternators though.
Old Aug 23, 2005 | 08:50 AM
EPDP99's Avatar
EPDP99
but do you think that since it gets necked down quite a bit that it is power robbing restrictive?
Old Sep 6, 2005 | 05:32 PM
EPDP99's Avatar
EPDP99
to the top. Any ideas
Old Sep 6, 2005 | 05:47 PM
BigF350's Avatar
BigF350
FTE Emeritus
Possibly, but the intercooler in itself provides a fair bit of restriction anyway.
Do you by any chance have a photo of it by any chance so we can visualise how restrictive it is?
Old Sep 6, 2005 | 05:57 PM
EPDP99's Avatar
EPDP99
stand by ill take a picture right now
Old Sep 6, 2005 | 06:12 PM
EPDP99's Avatar
EPDP99
picturs are in gallery under intercooler tube album
(put in links for you - BigF350)
https://www.ford-trucks.com/user_gal...=88296&width=2
https://www.ford-trucks.com/user_gal...=88297&width=2
Old Sep 6, 2005 | 06:17 PM
BigF350's Avatar
BigF350
FTE Emeritus
Ok, thanks for the photos.
It appears that the pipe would make a restriction - but relative to the restriction of the intercooler it would be minimal.
Anyone esle got an opinion?
Old Sep 6, 2005 | 06:22 PM
EPDP99's Avatar
EPDP99
BigF350, thanks for the super speedy reply...also thanks for adding the pics
Old Sep 6, 2005 | 06:32 PM
IB Tim's Avatar
IB Tim
That is a bit more then mine, does anyone know if the Dual Alt option has a different part # for "that" tube?
Old Sep 6, 2005 | 07:26 PM
efoster_01's Avatar
efoster_01
i have an 06 with the dual alternators and mine has a small crimp but its more ovald than mashed in like yours, or at least thats how it looks based on your pics, go to the dealership and look at an 06, if it is different, maybe you can get that tube?
Bone
Old Sep 8, 2005 | 12:25 PM
1ReDNeCK's Avatar
1ReDNeCK
By my catalog here at work, for the 03 and early 04 models, the part # on the tube is 5C3Z-6C646-CA. From Jul. 04 to current model 06, the part # is 5C3Z-6C646-EA. I will try to order both and compare them side by side to see what the difference is. I will post later with the results. Thanks
Old Sep 8, 2005 | 12:39 PM
1ReDNeCK's Avatar
1ReDNeCK
When I tried to order the older part #, it updates to the newer number. The only thing that I can come up with is from the factory on the earlier models, it was a different pipe, but as for a replacement part, all years will now use the same one.
Old Sep 8, 2005 | 03:22 PM
EPDP99's Avatar
EPDP99
do you think its possible to order the regular one and try to make it work just as long as it doesnt rub on the alternator?
Walleye Hunter
Dec 7, 2014 07:42 AM
powerstroke1869
May 6, 2011 01:44 PM
mrxlh
Aug 20, 2007 10:28 PM
badbrad60
Jun 26, 2007 11:30 PM
PowerstrokeJunkie
Jan 20, 2006 06:01 PM
