newbie need help?
Old Aug 18, 2005 | 09:29 PM
pwr6.0's Avatar
pwr6.0
newbie need help?
hi i have a 04 psd cc. and i have the afe stage2 proguard.also the afe 4'' cat back. along with the preditor programmer. it is throwing so codes 402,403,405,603and 2263. can someone tell me what they mean.also i have coolant over flowing. please help mike
Old Aug 18, 2005 | 09:40 PM
mrxlh's Avatar
mrxlh
Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Must read if you own a 6.0
https://www.ford-trucks.com/forums/showthread.php?t=3250...ad.php?t=325000
See you on the boards.
Enjoy FTE …..
Ryan
Old Aug 18, 2005 | 09:43 PM
mrxlh's Avatar
mrxlh
Please do a search of "coolant loss" in this forum. There is alot of reading in the threads that will pop up. It could be one of several issues, most common on the 04 seems to have been streched head bolts, and or defective head gaskets. Also a must read for you is in the predator thread that is stickied to the top of the forum.
Ryan
Old Aug 18, 2005 | 10:37 PM
kw5413's Avatar
kw5413
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Control Circuit
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0603 Powertrain Control Module Keep Alive Memory (KAM) Error
P2263 Turbo / boost related I believe.
Looks like your EGR Valve is toast and is affecting the turbo which would be typical.
Old Aug 18, 2005 | 10:38 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Keith, you have just exceeded the diagnostic capability of 75% of our techs
Old Aug 18, 2005 | 10:40 PM
kw5413's Avatar
kw5413
THAT...is pretty ding dang scary
Old Aug 18, 2005 | 11:06 PM
satcom40's Avatar
satcom40
That one reason for disconnecting the EGR.
Old Aug 18, 2005 | 11:10 PM
olfordsnstone's Avatar
olfordsnstone
KW, the wart strikes again eh?
T
kw5413's Avatar
kw5413
5 reasons.
Old Aug 18, 2005 | 11:11 PM
kw5413's Avatar
kw5413
This WART sometimes acts as if it is a festering blister...just keeps getting worse... til ya finally have to pop it.
Old Aug 18, 2005 | 11:12 PM
olfordsnstone
pwr6.0, please keep us posted on your success on this. Sounds like KW got the egr figured.
kw, would the affects of a failing egr also result in the coolant issue?
Tim
Old Aug 18, 2005 | 11:23 PM
kw5413's Avatar
kw5413
In my personal non-tech opinion it could at least indirectly. Matt can tell us the real reasons why.
But, It's kinda like when you get a head cold. Your lungs may be OK but you still can't breathe and you don't have much energy 'cause of the your body is working hard to compensate for your cold.
The EGR Valve locked in the open position causes your truck to work hard trying to figure out what the heck is goin' on. Plus the open valve is continually throwing contagions into system causing other kinds of nastiness. It can even impact your VGT valve which effects your turbo and there goes your boost.
The EGR valve creates an EVIIIIL vicious circle of events. It was surely created by the devil himself to inflict pain a suffering upon turbo diesel owners everywhere...
That's about as laymen and low tech as I can't get.
Old Aug 18, 2005 | 11:29 PM
kw5413's Avatar
kw5413
After I re-read that I guess I didn't answer your question...again, I could be way off base here...but, indirectly I feel it could have a cascade effect ultimately putting more load / pressure on the engine thereby causing the coolant to pop just as if it were under tow loads.
The more underpowered a sick truck is the more we try to put the wood to it so to speak...'cause we just know we can make her go....if we keep pushing the pedal hard enough.
Old Aug 19, 2005 | 12:36 AM
3/4ER's Avatar
3/4ER
Dr Keith,
If 4 out of 5 people suffer from diarrhea does the 5th person enjoy it?
Old Aug 19, 2005 | 12:56 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
pwr6.0,
Welcome to FTE.
Check out our Guidelines:
https://www.ford-trucks.com/guidelines.html
And the Read First: notices at the top of each forum, it will help you understand and navigate FTE easier.
See you around...
BigF350
