302 C-6 Flexplate
Old Aug 18, 2005 | 03:04 PM
XLR8DJ's Avatar
XLR8DJ
302 C-6 Flexplate
I just bought an 82 F150 4x4 with a bad 351W, my problem is that I am going to replace it with an 87 302HO motor that I had in my Mustang II, I have the 50oz imbalance fluid dampner but don't have the tooth count for the 50oz imbalance flexplate I need to buy. Does anyone out there have the correct tooth count for this flywheel? I think it probably is the 164 with the 11 1/2 in. converter pattern but am not sure and since I only have 2 days to get this done in by the time I get the old one out it will be too late to order the new one.
Thanks
Chad
Old Aug 19, 2005 | 09:04 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Chad, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Old Aug 23, 2005 | 12:32 PM
Kemicalburns's Avatar
Kemicalburns
i hope you plan on changing a few things on that 302 to move your rig better. if you built that motor for a car originally its gonna make power up hi in the rpm range which for a heavy 4x4 isnt good combo. so you may need to swap to a different cam,intake and carb depending on what you have. might give the specs of the motor.
AtlM5
Apr 5, 2024 05:14 PM
TexasGuy001
21
Jan 17, 2016 11:25 PM
bankog1
Oct 23, 2015 11:50 AM
bankog1
Oct 14, 2015 02:07 PM
AtlM5
May 16, 2015 08:36 PM
