Sponsored by: Auxito
Keyless Entry
Old Aug 18, 2005 | 11:39 AM
Fxxer's Avatar
Fxxer
Keyless Entry
This is just a little complaint, or maybe it is a problem. I used to have a 2000 ranger with keyless entry and you could lock and unlock that truck from a mile away it seemed. Now I have an 03' F-150 and from day one it just doesn't seem to work as good. I've checked the batteries in both key chains and you can sometimes be even 10 feet from the truck and you have to swing your arm around for it to finally unlock. I just though different truck so different characteristics. Any thoughs on if there is a sensor eye or antenna the needs to be adjusted or is this just the F-150.
03' Screw Fx4 5.4L
Old Aug 18, 2005 | 02:22 PM
Wild4kst8's Avatar
Wild4kst8
somethings not right... my 02 S'Crew keyless works from at least 50' away (barring no obstructions)
Old Aug 22, 2005 | 09:20 PM
Trublufords's Avatar
Trublufords
Poss bad security module located inside cab under dash in center- replaced one for same prob under 3/36 warranty.
Old Aug 22, 2005 | 11:48 PM
scotwms's Avatar
scotwms
Ford has both long range and short range transmitters, check your ford dealership they can sell you a long range transmitter. Plan to psend some $$$.
Old Aug 23, 2005 | 08:54 AM
Fxxer's Avatar
Fxxer
I lived with this for about 3 years now so instead of spending money or time tring to figure it out I guess I can just live with it. Thanks for all the input, but like I said it was just a little complaint!
Old Aug 24, 2005 | 09:54 PM
Trublufords
Long range and short range- news to me and our parts dept- need part # please!
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
matt71
19
Nov 9, 2010 04:02 PM
2Wise4aGM
Sep 19, 2010 04:12 PM
waldreps
Dec 23, 2006 09:50 AM
aldridgec
1997 - 2003 F150
Jan 26, 2003 08:54 AM
